belfastguzzi Posted May 10, 2005 Share Posted May 10, 2005 I had my tranny done here in March and after the recall it runs like a hot knife in cold butter. 51105[/snapback] Søren you had a transmission recall on a 2002 Scura? I thought that it was for earlier years. How did you get the recall information? Link to comment Share on other sites More sharing options...
Mike Stewart Posted May 11, 2005 Share Posted May 11, 2005 Joe, I was going to pull my transmission sidecover off and machine a larger pin to fix the oil leak and hopefully make the trans have fewer false neutrals. BUT after seeing the problem you had, I think I will get one from Guzzi even though it may take many months Mike Link to comment Share on other sites More sharing options...
Alex-Corsa Posted May 11, 2005 Share Posted May 11, 2005 I immediately pulled over and discovered trannie oil flowing (not dripping) out of the left side case. Closer inspection revealed a machined hole about the size of a dime. Well, my guess is this hole is where the trannie sidecase was "repaired" with a machining process instead of replacing the entire sidecase (which was "unavailable"). Does anybody at MGNA care about their customer base? Why have your bike off for months, try giving a call to Agostini and order the part(s) you need(there is English Speaking personel i.e.Peter is Australian).I can assure you they'll have it delivered. Then you can go to a descent dealership with the new parts and fix the bike. AGOSTINI-MG All the best Link to comment Share on other sites More sharing options...
