Guest tmartin Posted January 30, 2003 Share Posted January 30, 2003 Several lists have posted a K&N replacement air filter for Moto Guzzi. The number that keeps comming up is K&N 33-2682. I measured the air filter on my 2000 Sport and tried to find this filter on the K&N website using their "search air filters by dimension" with no luck. Is this part number for another model of Guzzi? Does anyone know if there is a K&N part number for a 2000 V11S? Thanks, Tracy... The dimensions of my filter are 8.75 X 5.25" (gasket measured edge-to-edge) or 8.375 X 4.875 (filter element only) Link to comment Share on other sites More sharing options...
dlaing Posted January 30, 2003 Share Posted January 30, 2003 Hmmmm, interesting.... I got a little better results by going here http://knfilters.com/universal/univsearchin.htm and entering: panel type filter Dim A Range 8.0-8.8 Dim B Range 4.75-5.3 Dim H Range 0.5-3.0 The result was part number 33-2006 Dim A 8.125 Dim B 5.250 Dim H 1.250 Perhaps a loose fit??? by fattening up the search I found that 33-2682 is 8.875 x 5.250 x 1.063 perhaps a tight fit??? Link to comment Share on other sites More sharing options...
Guest tmartin Posted January 30, 2003 Share Posted January 30, 2003 The 33-2682 appears to be an exact fit. The K&N search engine has to be "played" with to make it work. Thank you for your help. I'll order the filter and let you know if it really fits. Tracy... Link to comment Share on other sites More sharing options...
