gallo_se Posted May 25, 2005 Share Posted May 25, 2005 Hi everybody. I contacted the guys from rosso puro italia, asking if the solution "risers plus handlebar" that they have fits under tha V11 Le Mans fairing, and they said: YES! they adapted the plate plus risers plus handlebar to a V11 Ballabio and mounted the V11 Le Mans fairing, and it works. It is expensive, 320 euro, but seems to be the most convincing strategy. Link to comment Share on other sites More sharing options...
rocketeer Posted May 25, 2005 Share Posted May 25, 2005 Hi everybody. I contacted the guys from rosso puro italia, asking if the solution "risers plus handlebar" that they have fits under tha V11 Le Mans fairing, and they said: YES! they adapted the plate plus risers plus handlebar to a V11 Ballabio and mounted the V11 Le Mans fairing, and it works. It is expensive, 320 euro, but seems to be the most convincing strategy. 52668[/snapback] Hi gallo_se, Thanks for the information. I asked the same question earlier but got no response. As soon as I get another top clamp (I don`t want to drill mine as it is a limited edition with production number) that`s what I`m going to do. It looks like I`ll have to get a longer front brake hose but everything else should be okay. Link to comment Share on other sites More sharing options...
al_roethlisberger Posted May 25, 2005 Share Posted May 25, 2005 There's a thread in the "How To" section on fitting tubular bars, although it isn't specific to use with a LeMans fairing. I don't know of anyone that has fitted tubular bars and a riser in combination with the LeMans fairing, for fear of clearance issues. So yours might be a first. Photos and additional descriptions would be much appreciated for those interested. al Link to comment Share on other sites More sharing options...
Guest Ken Bruce Posted May 25, 2005 Share Posted May 25, 2005 Hi everybody. I contacted the guys from rosso puro italia, asking if the solution "risers plus handlebar" that they have fits under tha V11 Le Mans fairing, and they said: YES! they adapted the plate plus risers plus handlebar to a V11 Ballabio and mounted the V11 Le Mans fairing, and it works. It is expensive, 320 euro, but seems to be the most convincing strategy. 52668[/snapback] I know its not a lemans but i fitted raisers and high bars (like Kawa Z900 \ H2) and its transformed my V11 into a wonderful ride...just like a V11 ought to have been? Extended fluid pipes required. all in probably £200 in parts + my own time? Fitting the clutch pipe is NOT for the faint hearted tho... patience and long nosed pliers. Link to comment Share on other sites More sharing options...
