LowRyter Posted March 13, 2018 Share Posted March 13, 2018 PA. you might try Joel Levine repair. https://joellevinecompany.com/Speedo-Tach-Repair Saweet. Thank you. Alas, cable operated gauges only. really? he wouldn't work on it? Link to comment Share on other sites More sharing options...
Pressureangle Posted March 14, 2018 Share Posted March 14, 2018 PA. you might try Joel Levine repair. https://joellevinecompany.com/Speedo-Tach-Repair Saweet. Thank you. Alas, cable operated gauges only. really? he wouldn't work on it? Noop. Link to comment Share on other sites More sharing options...
LowRyter Posted March 14, 2018 Share Posted March 14, 2018 I did see a thread on WG where a fellow soldered the coil pack back together. It was the thread I used to learn how to get the bezel off (hose clamp). Luckily mine was only the counterweight. Link to comment Share on other sites More sharing options...
Pressureangle Posted March 21, 2018 Share Posted March 21, 2018 I'll have to measure the wire, source it, unwind the coil and count turns then re-wind it and solder it in place. Pretty fine work. My broken wire was the one from the inside of the coil, broke right close to the coil wrap where it peeks out the side. Had it been the outside wire I'd have given up one turn and had plenty to work with. Link to comment Share on other sites More sharing options...
