Sometimes when I try to fire up my '02 LeMans it almost seems like the amp draw from the starter is too much for the battery to deal with. I just replaced the original battery with an Odyssey PC545 and its still reacting the same way. I've always ASSumed that a relay either works or it doesn't, but now I'm wondering if I should try a Bosch relay.
Guest Nogbad
The high current connection is direct to the starter through the solenoid contact from the battery. As above, clean all the connections and check the grounds.
