belfastguzzi Posted June 19, 2005 Author Share Posted June 19, 2005 1) WHAT? 2) Water in your whisky??! 3)Are you mad???? 54471[/snapback] 1) You heard me 2) I was only refering to whisky, not to whiskey. 3) Link to comment Share on other sites More sharing options...
belfastguzzi Posted June 21, 2005 Author Share Posted June 21, 2005 The old loopframes vented almost straight to atmosphere- they went through a (useless) recovery box, so the idea has possibilities. That won't fix your root problem, though, which is that your bike runs too cold to evaporate off the condensate. I'd think about restricting airflow around the cylinders to keep the bike warmer. 54395[/snapback] It's not a real answer to oil not having time to get hot enough, but I'm just thinking that it could be worth blanking off the oil cooler. Link to comment Share on other sites More sharing options...
Guest Nogbad Posted June 22, 2005 Share Posted June 22, 2005 It's not a real answer to oil not having time to get hot enough, but I'm just thinking that it could be worth blanking off the oil cooler. 54617[/snapback] Don't bother. There's a thermostat in the oil circuit that prevents flow through the cooler until the oil is hot enough. I suppose it could jam open..... Link to comment Share on other sites More sharing options...
belfastguzzi Posted June 22, 2005 Author Share Posted June 22, 2005 Don't bother. There's a thermostat in the oil circuit that prevents flow through the cooler until the oil is hot enough. I suppose it could jam open..... 54637[/snapback] oh yeah, thanks. I should have thought about that. Link to comment Share on other sites More sharing options...
