txrider Posted June 20, 2005 Posted June 20, 2005 Occasionally the question will be asked about what to use to seal an electrical item, connector, whatever and I recall we absolutely could not use acetic acid cure RTV's in out aircraft display manufacturing at wotk. Instead we used alcohol cure RTVs but at the time they were expensive and hard to get. Well here's some good news- http://www.logwell.com/tech/servtips/RTV.html A good article on what to use and finally a low cost and easy to find material for use around electrical components.
