I like your plates. And the breva gets?
54813[/snapback]
Can't make my mind up from the following:
GU51ACE
GU51APE
GU55BUN (my handle!)
GU51BUN (nearly my handle!)
GU51GAS
GU51GEL
GU51GUZ
GU51LAD
GU51MAD
GU51NUT
Nice pair! :drink: Good for you!
You better watch out, when your not around they will probably will start marking their territories, leaving their scent all over the place.
54816[/snapback]
Hah! The Corsa is already doing that - sprays oil from both head gaskets - not what I expected from a blueprint engine or a bike that cost so much - somwhat less than gruntled by that!
But the ride...oh, the ride... :D
Guest Steve_W
Got my two thoroughbreds lined up together at last - hoping to breed from them!
54812[/snapback]
You suck! :bbblll:
No, I'm not jealous at all, not at all. :glare:
Really sweet rides, though, kinda like having a P-51 and a Spitfire to play with!
IS it the gaskets, or the scewholes? the front and rear cover screws need an alu ring under the head, and correctly tight. If it is between head and cover, you can mount it with a bit of blue silicone under it.
