Thanks for the pic Al. :bier:
  al_roethlisberger said:
Ignore the blue fitting seen inside the filler hole(as this was part of a project in the fuel pump relocation thread) but here you can see a portion of the indentation and mounting brackets for the normal foam chin pad.  The only difference for the CF version is that it bolts on through the piece instead of using the rubber grommet mounting system.
http://www.v11lemans.com/forums/index.php?...ype=post&id=583
60356[/snapback]
This is the other end of th ebig hole in the tank top. You can see the threaded inserts where the pad screws into the tank.
60388[/snapback]
Thanks. I understand it now. :bier:
60388[/snapback]
This is looking rather orange for a matt black scura tank. Are the flashes of colour spreading on your bike?
60414[/snapback]
It could be your bloodshot eyes. Have you been travelling a lot recently?
