quazi-moto Posted July 6, 2005 Posted July 6, 2005 I might try the Marelli PF4C TPS (HD p/n:27271-95) on my '02 LeMans. When I set the right hand throttle plate fully closed do I have to do anything with the fast idle/choke lever or linkage?
Guest ratchethack Posted July 6, 2005 Posted July 6, 2005 Quazi, you need to disconnect 'em both. First disconnect the linkage rod by *carefully* popping off the ball connector on the right-hand side, then loosen the set screw on the bottom of the right-hand TB so that the fast idle won't hold the throttle open. Make sure the tiny wheel on the fast idle follower (on the TB) that rides on the fast idle cam plate doesn't touch the cam plate. If you can spin the wheel, you're there.
