Guest Darth Maul Posted February 15, 2003 Posted February 15, 2003 How many type of Cross-Over is there in the market...??? Anyone knows what is the difference in terms of performance between the Stucchi and the Lameroni... n other crossover...??? I dont intend to change the stock exaust can but might get a PCII in the future.
Janusz Posted February 16, 2003 Posted February 16, 2003 In my opinion Stucchi X-over works the best and certainly looks the best. Definitely gets rid of 4000 RPM dip. You'd be better off with PClll then PCll. Stock cans respond great to drilling holes in the back under the finishing plates. Then you adjust your sound and response by drilling two or three small holes in the finishing plates inside and around a central hole. Then you can add some holes one by one until you have enough to your liking. I have only 3 small holes in each finishing plates and it seems enough. With the finishing plates removed completely (for testing purposes only) the sound is too much and resembles Harley too much. Performance seems to be improved if anything.
