Guest ratchethack Posted July 17, 2005 Share Posted July 17, 2005 I'll tell you a secret too: if you're not afraid of taking apart your seat, you can VASTLY improve it's comfort for about $5. 56279[/snapback] So Skeeve - are you lookin' for somebody to beg you to spill the beans - or exactly what's the point of your post? Link to comment Share on other sites More sharing options...
soloNH Posted July 17, 2005 Share Posted July 17, 2005 What he said!!! Link to comment Share on other sites More sharing options...
dlaing Posted July 17, 2005 Share Posted July 17, 2005 I'll tell you a secret too: 56279[/snapback] Are you teasing us? What is the secret? A raw steak vacuum packed in antiseptic? I tried adding Gel, but it got too hot. I tried sculpting, but the foam got too thin. My options were then to start with a new block of foam, and new vinyl, or to get a Rich Maund or a Corbin. I went with the Corbin, which is much better on the butt than stock, but it slopes down too much and transmits more vibration. I might try some sheep with a foam ramp to keep me from sliding forward. I also tried tilting the rear subframe back about 1mm, (boring the mount poin with a dremel) but that did not noticeably help the seat angle. So what is the secret? Neoprene, latex foam, Tempurpedic® foam, urethane foam? Gel? A white seat would be butt ugly, but would stay cooler in the sun. I might consider gel, if I went with a brighter cover....maybe red or silver??? The black vinyl actually got harder from getting cooked by the heat of the gel. I think Rich Maund insulates his gel with a layer of foam. EDIT I took to long to post. Yah, what Ratchet and SoloNH said Link to comment Share on other sites More sharing options...
