beauchemin Posted July 29, 2005 Posted July 29, 2005 I thought that this shock did not have adjustable high-speed compression. However, according to the Ohlins installation manual, this shock comes with low AND high speed compression adjustment. Can anyone verify if this is true? Here's the oline PDF: http://www.ohlins.com/pdf/mounting_instructions/MG127.pdf
dlaing Posted July 29, 2005 Posted July 29, 2005 Wow! If true, you just changed my mind about my next shock!
beauchemin Posted July 29, 2005 Author Posted July 29, 2005 Wow! If true, you just changed my mind about my next shock! 57009[/snapback] I agree that it is very tempting if that feature is there. The only problem is that it is still an off-the-shelf shock (except that you will get the proper spring rate for your weight). What you might NOT get is the correct damping range. The Wilbers advantage (as with Penske, or any other custom unit) is that you get it tailor-made for both spring rate, and the appropriate damping ranges for the adjusters.
al_roethlisberger Posted July 29, 2005 Posted July 29, 2005 Several of us have that model, and I don't recall any mention of "high speed damping", but maybe they have updated the model ....orrr, mine may have this adjustment, and I just didn't realize. Since I don't have my bike here in this State, I can't run out and look, but once I get out to NC I'll take a look and see. al
gthyni Posted July 29, 2005 Posted July 29, 2005 No, only the PRX units have separate high and low speed compression damping adjustment. What make the Öhlins unit so excellent is not the adjustability but the low inner friction which makes it work so smoothly. To learn more about the inner working and adjustment of shock absorbers the Öhlins user manual is a good read regardless of if you have a Öhlins, Sachs, Penske etc (or Paioli like me) Downloadable for free ffrom Öhlins: http://www.ohlins.se/pdf/07241-02.pdf more manuals: http://www.ohlins.se/mc_manuals.shtml
dlaing Posted July 29, 2005 Posted July 29, 2005 So, is this erroneous, http://www.ohlins.com/pdf/mounting_instructions/MG127.pdf ? Or from the mother country: http://www.ohlins.se/pdf/mounting_instructions/MG127.pdf Öhlins shock absorber 46 HRCSYour new Öhlins shock absorber features the following adjustments: - Compression damping adjustment - Rebound damping adjustment - Hydraulic spring preload adjustment Compression damping: Adjustments are made on top of the reservoir. Low speed adjustments: Slotted centre screw High speed adjustments: Hexagon screw. Rebound damping Adjuster wheel on the piston shaft above the end bracket. Hydraulic spring preload Adjustments are made by turning the knob on the hydraulic adjuster. Clockwise for harder adjustment, counter clockwise to release the preload. When delivered the Öhlins products are subject to continual improvement and development. Consequently, although these instructions include the most up-to-date information available at the time of printing, there may be minor differences between your suspension and this manual. Please consult your Öhlins dealer if you have any questions with regard to the contents of the manual.
gthyni Posted July 29, 2005 Posted July 29, 2005 So, is this erroneous, http://www.ohlins.com/pdf/mounting_instructions/MG127.pdf ? 57017[/snapback] Oops, the pdf i posted said only models with PRX in the name had that feature. I don't know and I only have a Paioli so I can't check.
