Here 's an info I would like to share with you and it may be usefull.Especially if you like to make a stok on these parts.
Rescently I have changed the front wheel bearings on my 1100i Sport Corsa.
I used these SKF 6304-2RS1 (this one is only MADE IN ITALY version on the market as I have seen)for the right side bearing as we sit on the bike and the other is 6205-2RSH
I have these Marchesini rims(stock ones) with the Brembo decal on them , dunno if it is the same for the stock rims V11 , but I think it has to be AFAIK
If anyone knows the SKF bearing numbers for the back wheel , just write it down here.
Thanks :helmet:
Let's keep that thread going!
57240[/snapback]
Yah, it is only up to 9 pages and we still have not figured out how to make a bearing spacer :lol:
Please note, that as accurately as we have discerned, the combination of a 6304 and 6205 appears on bikes with a solid axle.
Bikes with a hollow axle have a pair of 6205 bearings.
6304 is 20 x 52 x 15 mm
6205 is 25 x 52 x 15 mm
As far as I know, only the later model bikes equiped with Ohlins had the hollow axle, but I could be wrong.
EDIT I was wrong; see Orangeokie's post below.
The rear WHEEL bearings are 6204 double sealed.
SKF number 6204-2rs1 (the 1 can be replaced by an H for superior seal and an L for lower friction)
NAPA number 6204-2rsj is really an SKF 6204-2rs1
If anyone knows the bearing number for the rear drive, please post them here and in the rear wheel woes thread :P
Thanks for the clarification, Dave. I was just wading thru the "rear axle woes" thread hunting for the right PNs, and my eyes were starting to bleed... :blink:
. . . As far as I know, only the later model bikes equiped with Ohlins had the hollow axle, but I could be wrong.
57245[/snapback]
As someone pointed out in another thread, the 2003 LeMans (Marzocchi) has the hollow axle but the Ohlins Rosso Corsa has the solid axle. go figure.
I have the Rosso Corsa and it has the hollow axel
57465[/snapback]
Does anyone know of a hollow axle Rosso Corsa in the States? :huh2:
