Skeeve Posted August 14, 2005 Posted August 14, 2005 This could be a good deal!PCIII 57793[/snapback] What's the difference in capabilities between the non-USB version shown and the PC3usb? Can the software "throttle pump" feature be retrofitted to the older serial PC3's, or is that strictly a feature on the newer -usb model? Other than that, all I can say is that someone in the UK/EU might be able to score a real deal, but I've already been skinned on Ebay more than once, so I adhere to a strict "not outside my continent" buying protocol... Ride on!
gthyni Posted August 21, 2005 Posted August 21, 2005 £47 it went for What's the difference in capabilities between the non-USB version shown and the PC3usb? Can the software "throttle pump" feature be retrofitted to the older serial PC3's, or is that strictly a feature on the newer -usb model? No, if you want the latest features, a finer grained map och use the latest software from Dynoje you must buy the USB-version. If you just want to dial in the FI a £47 used PCIII does the jobs perfectly OK.
