Guest Nogbad Posted August 24, 2005 Share Posted August 24, 2005 OK, the damping adjustment front and rear seems to work and make a difference. After reducing the compression at the rear to 10 clicks in, the bike is more comfortable and handles a lot better on ripply bends with rough surfaces. However, it now bottoms on bigger bumps OUCH. Increasing the preload causes it to top out on crests and makes the sag too small. Either A. The rear suspension is simply too crude having no rising rate linkage. Or B. The stock springs are too soft / wrong rate or something. I am not a heavy guy at about 150 lbs Link to comment Share on other sites More sharing options...
Skeeve Posted August 24, 2005 Share Posted August 24, 2005 OK, the damping adjustment front and rear seems to work and make a difference. After reducing the compression at the rear to 10 clicks in, the bike is more comfortable and handles a lot better on ripply bends with rough surfaces. However, it now bottoms on bigger bumps OUCH. Increasing the preload causes it to top out on crests and makes the sag too small. Either A. The rear suspension is simply too crude having no rising rate linkage. Or B. The stock springs are too soft / wrong rate or something. I am not a heavy guy at about 150 lbs 58459[/snapback] Given that there's no rising rate linkage, the V11 would seem to be an ideal candidate for a progressive rear spring or air shock. Does Fournales make a shock for the monoshock Guzzis? Or Prog. Suspension offer a replacement spring? I know that several have written about sub'ing FZ1 springs for the stock fork springs; what manufacturer's stock shock parallels the dimensions of the Guzzi stocker, so that prog. springs for that alternate might be obtainable? Tis a puzzlement... Great question for you to have asked, tho'! Link to comment Share on other sites More sharing options...
Guest Nogbad Posted August 24, 2005 Share Posted August 24, 2005 I have e-mailed this place. I've really been enjoying my V11 lately, and am moving away from the idea of swapping it for a Buell. So I think I'm going to have the bike professionally set up to suit me, if necessary with new progressive rate springs front and rear. We'll see what these guys recommend! Set-Up Engineering Link to comment Share on other sites More sharing options...
beauchemin Posted August 24, 2005 Share Posted August 24, 2005 So I think I'm going to have the bike professionally set up to suit me, if necessary with new progressive rate springs front and rear. We'll see what these guys recommend! Set-Up Engineering 58496[/snapback] Since you seem to have the correct spring rate, it sounds like the high-speed compression damping is too high. It will be interesting to hear what Setup recommends. I think that the answer is to have a shock with position sensitive damping (which I believe is what the WP shocks on the link-less KTMs have). A close second is to have both low and high speed compression damping adjustment. Link to comment Share on other sites More sharing options...
wavey_davey Posted August 24, 2005 Share Posted August 24, 2005 Since you seem to have the correct spring rate, it sounds like the high-speed compression damping is too high. It will be interesting to hear what Setup recommends. I think that the answer is to have a shock with position sensitive damping (which I believe is what the WP shocks on the link-less KTMs have). A close second is to have both low and high speed compression damping adjustment. 58511[/snapback] I live about 2 miles from Set Up, friendly and knowledgable bunch. I popped in there on the V11 once and they gave me some free advice, as I had backed the pre-load off the rear shock to it's minimum to try and help get the over-stiff rear-end to respond better on bumps. I was aso concerned that, in moving the rear reservoir union I might have lost the pressurisation, which I hadn't btw. It was soon clear from what they said that I'd over-done it, but they liked the front end settings (all this based on a quick "bounce each end of the bike up and down a couple of times-you don't get much of anything for free!). The front end was pretty close to standard settings. I also got to dribble over Ewan Magregor's immaculate MV Agusta Every test I've read in American bike mags of the Scura have criticised the behaviour of the rear suspension over bumps, and as they say, ANY suspension can be made to work well on smooth roads! My view is it comes down to 3 things; 1/ The rear suspension has to be overly-stiff (in relative terms) to take account of un-sprung weight from the bevel box. 2/ The linkless set up means the set has to be over-stiff to prevent "bottoming out" (i.e.reaching limit of travel) 3/ The rear swing arm is too short (one scura test compared the length with a Honda VTR1000, which was a good 5 inches longer from memory), hence limited travel. I think given loading a Scura up with top notch components doesn't really improve things greatly, you're gonna struggle to get a step change in behaviour? Just my 2 cents... Dave Link to comment Share on other sites More sharing options...
dlaing Posted August 25, 2005 Share Posted August 25, 2005 HyperPro makes a rising rate spring for our Sachs, however I am concerned the spring rate is too heavy for the under 100KG riders. The European HyperPro may have more options than HyperProUSA. If you dare read through http://www.v11lemans.com/forums/index.php?...opic=4213&st=75 you can see what we know about their springs. Here is the Readers Digest® version for the rear spring: They give it a low measurement of spring rate = 90.13 Nt/mm. = 9.190556 Kg/mm = 515.0929 lbs/inch and a high measurement of rate = 144.2 Nt/mm. = 14.70407 Kg/mm = 824.103 lbs/inch The low measurement is probably suitable for a 90KG rider, while the high measurement is probably suitable for a 150KG rider. The low measurement may or may not get sucked up by the preload and the high measurement, may or may not be even within the range of travel. So, we need a guinea pig. I put a 475#/inch spring on mine and suspect it is a little too light for my 210++ pounds. I had to set the preload on tight side to keep it from bottoming too easily. I think a progressive spring would be better, but I am thinking 450# after preload transitioning to 600# at the bottoming point. so the HyperPro numbers scare me, but they may not be bad, depending on how they measure the spring. The bike is alot more comfortable on the rear hits if I slide forward, so what I really like is the idea of a longer swingarm....or a seat that is comfortable when seated right up at the tank. Link to comment Share on other sites More sharing options...
Skeeve Posted June 18, 2007 Share Posted June 18, 2007 So, what's the O.D. of the stock Sach shock [ergo, what I.D. should be used when ordering springs?] I've seen posts stating 2.25" ID springs & 2.50" ID springs; I suspect the latter is correct, 'cause by eyeball it looks like the 2.25" springs would be likely to rub. But I'd like to be certain... Link to comment Share on other sites More sharing options...
Guest ratchethack Posted June 18, 2007 Share Posted June 18, 2007 Skeeve, the OD of the Sachs shock isn't significant. The spring retaining collars that actually accept the springs are 2.2". The stock Sachs spring measures 2.232" ID, and 3.090" OD. That's not accounting for paint. Link to comment Share on other sites More sharing options...
dlaing Posted June 19, 2007 Share Posted June 19, 2007 This thread has some info: http://www.v11lemans.com/forums/index.php?...=5488&st=15 Fuelcooler and I each went with 2.25" x 6" He got a 500# Eibach, and I got a 475# Hyperco Hypercoil for my Sachs, which was too light for my ~230 riding weight unless my seating position was all the way forward. I now have a 550# Hypercoil on my Penske, but I am seriously considering the HyperPro (different company than HyperCo) for their rising rate spring. I previously thought it would be too stiff, but I think it is worth a gamble to try it. Link to comment Share on other sites More sharing options...
Skeeve Posted June 19, 2007 Share Posted June 19, 2007 Thanks guys, that was the info I needed! Link to comment Share on other sites More sharing options...
RacerX Posted June 20, 2007 Share Posted June 20, 2007 Timely post. I am now set up to offer all HyperPro products. I can offer a spring kit (front and rear) for the V11 Sport folks (discounted if you mention this thread); http://www.guzzitech.com/store/HyperPro-FS.html Watch for all the rest of the products (mono rear shocks & steering dampers) linked on the main page at GuzziTech.com in the very near future. Link to comment Share on other sites More sharing options...
badmotogoozer Posted June 21, 2007 Share Posted June 21, 2007 I just received my HyperPro damper. I'm sure it would have been less hassle from you... VERY happy with it! Was running the POS Bitubo on zero setting until I discovered it had shit the bed and was screwing up my steering. Ran without a damper at all for a while and thought that was pretty good until I put the HyperPro on. Everything is noticeably much smoother now. Happy I coughed up the dough. A rear spring is in order now though... cheers, Rj Link to comment Share on other sites More sharing options...
docc Posted June 21, 2007 Share Posted June 21, 2007 BMG, Do you have a link and part number for the damper? ( My 1.0 springs from Traxxion are here , with their excellent instruction pac and spacers; the Ohlins should be at Corse Motorsports tomorrow. ) Link to comment Share on other sites More sharing options...
luhbo Posted June 22, 2007 Share Posted June 22, 2007 I just received my HyperPro damper..... Rj Was it interchangeable with the Bitubo part or did you need a special mounting kit? Hubert Link to comment Share on other sites More sharing options...
dlaing Posted June 22, 2007 Share Posted June 22, 2007 Apparently they sell with or without an OEM mount http://www.hyperprousa.com/catalog.php?cat...ke=Moto%20Guzzi part number varies with colors Curious to read what Ryan installed Link to comment Share on other sites More sharing options...
