Guest Britcheflee Posted August 31, 2005 Posted August 31, 2005 Are there any threads here about adding lighting (small spots) to V11 Ballabio? Is there a spare fuse or location to tap into - thinking of getting very small spots (more to be more noticable on the road than lighting at night) - would like to know if this can be done fairly easily. Lee
Guzzirider Posted August 31, 2005 Posted August 31, 2005 An easier solution may be just to upgrade your headlight bulb- I recently did this with the Jackal and it has transformed lighting at night. The charging system copes with it fine. I used a 100/80watt bulb which it technically illegal but you can now see at night which is nice! Will do my V11 too as soon as the current bulb blows. Guy
Skeeve Posted September 1, 2005 Posted September 1, 2005 An easier solution may be just to upgrade your headlight bulb- I recently did this with the Jackal and it has transformed lighting at night. The charging system copes with it fine. I used a 100/80watt bulb which it technically illegal but you can now see at night which is nice! Will do my V11 too as soon as the current bulb blows. Guy 59047[/snapback] I am surprised to read this; these high-wattage bulbs are known for melting wiring harnesses is bikes that aren't already well-known for having electrical gremlins! I still haven't figured out why nobody produces an 80/65w bulb, which would be noticeably brighter than a stock one w/o producing so much more current demands that it requires stringin' new wire, but whatever!
Guzzirider Posted September 1, 2005 Posted September 1, 2005 Yes the Jackal runs fine with the higher output bulb- and I used to have the lights on most of the time. I have recently sold the Jackal to my stepfather and my Mum is now riding pillion on it- she is 58 and calls herself a biker babe! I think the charging systems on modern Guzzis are ok- I run heated grips on my V11 with no issues at all. Guy
al_roethlisberger Posted September 7, 2005 Posted September 7, 2005 I just rewired the headlight directly to the battery with appropriate relays, and the stock bulb miraculously was plenty bright enough There are a couple loose power leads here and there, but most are underpowered for lights or have not been clearly identified as a good/reliable power source. One is the lead one might find on a few bikes for the old electric petcock, and there is a pair of loose bullet connectors up under the rear tail-piece near the tail-light that might be useful. But for lighting, well anything really, I'd just use one of these sourced(if switched power) to control a relay to power these items directly from the battery. This is what I did for louder horns, headlight, and heated grips. al
