bigbikerrick Posted September 7, 2005 Share Posted September 7, 2005 I changed the stock h4 bulb with a Lockhart Phillips racing ion yellow bulb. I was looking for the yellow tinged headlight look so cars would notice it more in traffic( keep cagers from turning left in front of me) I put the same bulb in my cbr 600 with dramatic results, very yellow from straight on, with a bluish/purple hue when viewed from an angle, and excellent road illumination at night. on the V 11, its much more subdued. My question is can that round "reflector" /deflector in f ront of the bulb be removed? whats its purpose? Thanks ! Link to comment Share on other sites More sharing options...
TX REDNECK (R.I.P.) Posted September 7, 2005 Share Posted September 7, 2005 http://www.v11lemans.com/forums/index.php?...051entry46051 Link to comment Share on other sites More sharing options...
al_roethlisberger Posted September 7, 2005 Share Posted September 7, 2005 Please don't interpret this in a negative way, but a vast majority of LP products really are of low quality.... "bling for the masses". This is often especially true of their various lighting options(from personal experience). If you are interested in noticeably better lighting, I would recommend investigating rewiring the power supply to the headlight as discussed a few times here(search headlight or similar), or look at bulbs from mainstream manufacturers. Good luck with your selection though al Link to comment Share on other sites More sharing options...
DVH Posted September 7, 2005 Share Posted September 7, 2005 Please don't interpret this in a negative way, but a vast majority of LP products really are of low quality.... "bling for the masses". This is often especially true of their various lighting options(from personal experience). If you are interested in noticeably better lighting, I would recommend investigating rewiring the power supply to the headlight as discussed a few times here(search headlight or similar), or look at bulbs from mainstream manufacturers. Good luck with your selection though al 59593[/snapback] I would second that, rewired the last guzzi light with dramatic results. In standard format it was losing 1.5v through the system Link to comment Share on other sites More sharing options...
bigbikerrick Posted September 8, 2005 Author Share Posted September 8, 2005 Please don't interpret this in a negative way, but a vast majority of LP products really are of low quality.... "bling for the masses". This is often especially true of their various lighting options(from personal experience). If you are interested in noticeably better lighting, I would recommend investigating rewiring the power supply to the headlight as discussed a few times here(search headlight or similar), or look at bulbs from mainstream manufacturers. Good luck with your selection though al 59593[/snapback] Thank you Sir, I will search here I guess its all about wiring it directly with a relay Link to comment Share on other sites More sharing options...
