Does anyone know the paint number for the bergundy v11 sport as it seems the guzzi tank bag has raped my tanks finish cheers. :(
60292[/snapback]
I have had a look through Guzziology for you- no luck I am afraid.
If you find out please let me know as Helen's tank is scuffed up too.
cheers
Guy :helmet:
cheers
Guy  :helmet:
60297[/snapback]
No worries
I gave up trying to source the correct paint code, not that anyone in the USA would have been able to probably make heads/tails of it anyway :huh2:
So I just went to a pro motorcycle/auto paint shop, and they custom computer matched it perfectly when they painted my 2003 tank.... which I promptly chipped! :bbblll:
al
cheers
Guy  :helmet:
60297[/snapback]
Went to a local spray painter this morning to see if he could match the paint on the tank although he said to get the actual paint would probably be a bit difficult he showed me a range of colours from house of kolors from the states and there seemed to be quite a few that were as far as i was concerned exactly the same.So if you find a sprayer using house of kolor it may be worth checking the range out.Hope this helps! :ninja:
60499[/snapback]
Thanks mate- I am bodging the scuffs with colour magic at the moment but when the time comes for a respray I will go down the same route as yourself.
Guy :helmet:
Guest lowgloss
The factory colors are basecoat / clearcoat colors. The House of Kolor samples you saw were probably 3 stage (Candy) colors. These are expensive to spray and hard to repair without a complete repaint of the tank. Candy colors are however some of the most beautiful colors available.
I posted in the past that PPG/Nexa Autocolour have a good motorcycle deck with a number of Moto Guzzi colors in. They also have a brand new update that has additional Guzzi colors although I haven't seen the chips, so can't comment on what was added.
