Marc B Posted September 16, 2005 Share Posted September 16, 2005 The Bike is a 2000 V11 Sport In the last week the bike has a very hard time starting about 50% of the time After it starts the bike runs great. It’s very random, Sometimes first starting in the morning, Sometimes after a long ride and every thing in between, It seems like it's not getting fuel, i'm not really up to speed on fuel injection, but perhaps it's taking to long to build pressure in the system??? Thanks Marc Link to comment Share on other sites More sharing options...
Cliff Posted September 16, 2005 Share Posted September 16, 2005 Listen to the fuel pump when the ignition is turned on. Does it change sound significantly. Try turning key on twice (waiting for the fuel pump to stop) before hitting the starter. Link to comment Share on other sites More sharing options...
Murray Posted September 16, 2005 Share Posted September 16, 2005 The early V11's had a batch of Siemins relays that were pretty average. Might be worth checking out if they relays have been swapped. The random starting seems to fit at least. Link to comment Share on other sites More sharing options...
Guzzirider Posted September 16, 2005 Share Posted September 16, 2005 Even late V11s have crappy relays too. The guy responsible for chosing them in Mandello should be hung upside down from a lamp post Mussolini style for the amount of bother they have caused. Guy Link to comment Share on other sites More sharing options...
Guest PAULSMART Posted September 16, 2005 Share Posted September 16, 2005 I have / had exact same symptoms - I now swap the relays about, which has always worked so far - definetly get rid of siemens relays though. Paul Link to comment Share on other sites More sharing options...
Marc B Posted September 16, 2005 Author Share Posted September 16, 2005 The fuel pump sounds consistant I have the grey bosch relays, I'll try swapping them around. Thanks Marc I have / had exact same symptoms - I now swap the relays about, which has always worked so far - definetly get rid of siemens relays though. Paul 60412[/snapback] Link to comment Share on other sites More sharing options...
quazi-moto Posted September 16, 2005 Share Posted September 16, 2005 I've had some starting quirks on my '02 LeMans which have become more frequent and annoying. Firstly, sometimes when I hit the button I get nothing, no cranking at all. Then if I cut the bars a little it'll usually start to crank. Secondly, with the Odyssey battery it cranks right over from cold, but once the motor is thoroughly warmed up it cranks very slowly after re-starting. It behaves like there's some serious amp draw issue or something. It might just be some crusty connections, I don't know yet for sure. Link to comment Share on other sites More sharing options...
Marc B Posted September 20, 2005 Author Share Posted September 20, 2005 I swapped the relays around and the bike starts consistantly now.. What I'd like to know which relay is which, I couldn't find any info in my manual or repair book. Thanks For all the Info!!! Marc Link to comment Share on other sites More sharing options...
Guest ratchethack Posted September 20, 2005 Share Posted September 20, 2005 Front to back, it goes: START, LIGHTS, NEUTRAL, ECU, and EFI. For the START relay, may I most highly recommend the higher-amperage GEI relay from "Pyro" Dan the Guzzi Relay Man (ref. search on "GEI relay" for Dan's contact coordinates). If y'er so inclined (I am), you can carry the replaced START relay as a spare. Link to comment Share on other sites More sharing options...
Guest ratchethack Posted September 20, 2005 Share Posted September 20, 2005 I've had some starting quirks on my '02 LeMans which have become more frequent and annoying. Firstly, sometimes when I hit the button I get nothing, no cranking at all. Then if I cut the bars a little it'll usually start to crank. Secondly, with the Odyssey battery it cranks right over from cold, but once the motor is thoroughly warmed up it cranks very slowly after re-starting. It behaves like there's some serious amp draw issue or something. It might just be some crusty connections, I don't know yet for sure. 60459[/snapback] Quazi, check the bullet connectors under the tank on the left-hand side on the wires that come from the clutch switch. These are notorious sources of exactly the symptoms you describe, per many posts on this. A good cycling of the connectors, careful re-crimping and application of dielectric grease has cured this in many cases, mine included. WRT the slow warm start - as you noted, cleaning up and re-seating all ground paths is always a good idea. Link to comment Share on other sites More sharing options...
quazi-moto Posted September 20, 2005 Share Posted September 20, 2005 Thanx Ratch! I've got a few odds & ends to tidy up on the bike so I'll be looking at those connectors ASAP. Link to comment Share on other sites More sharing options...
