Some of you may recall I had my cans cut down and mounted under my bike. (See attached photo) Ever since I did this I’ve been meaning to get one of Cliff Jefferies’ MyECUs.
A few weeks ago I fried my stock ECU doing something stupid… never mind it is a long and embarrassing story. But this gave me a perfect excuse to send for Cliff’s programmable one.
He quickly whipped one up for me and an Optimiser too, and I just had my first ride.
My Bike is a 2003 and it has always had a loping uneven idle that left you feeling like you weren't really sure the engine would be there when you gave it throttle. Now It feels like a Swiss watch. Very immediate and responsive. Not just at idle but throughout the throttle range the response is several orders of magnitude crisper, and snappy. It feels as though I have an entirely new bike!
We are so lucky to have guys like Cliff.
Thanks Cliff!
Frank
http://www.jefferies-au.org/MyECU/index.htm
  • Replies 97
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Hi Frank, good to hear from you as we haven't heard much from you recently. Did you get your bike back in one piece after your accident? You are going to have to tell us, what fried your ECU. If I don't ask someone else will. Could you give us a figure of what your My15 plus the Optimiser is worth delivered?
Rob
Hi Rob,
I think it came to about $700 USD. For the ECU and the Optimiser unit. Cliff has the prices on his web site. I think he got it to me about 7 to 10 days after I sent him my dead ECU. It was REALLY quick.
Thanks for asking about the hit and run I had. After about 4 months of waiting for a replacement kickstand bracket, I had a buddy of mine cut up my bent one and weld it together into a usable shape. Can you believe it, when I got home from his house there was a message on my machine from the dealer that my bracket had arrived that very day!
In the meantime while I was without a bike I decided to buy a 1995 Ducati 900 SS SP. So lately I've been getting that up to speed.
Anyway, after sitting for a long time and it was getting old anyway, the battery in my V11 gave up. The positive lead was so tight that I couldn't lift the battery to get at the ground to disconnect it first. So I decided to disconnect the positive first to gain a little more working room. Well, we all know this is a bad idea, and sure enough, the wrench slipped and bridged the ECU case with the positive terminal. Well, that was it for my ECU.
Alls well that ends well though, because my bike runs about a million times better now with Cliff’s ECU, and I haven't even got the O2 sensor mounted in the system yet. I've never gotten more than 31 miles a gallon so I was running pretty rich. Even after I gutted the exhaust, I was still always running very rich. With stumbles off of idle and so forth. But now it is solid as a rock! I am really glad I did it.
Frank
That's great news (except the accident and frying the ecu part). We are lucky to have people like Cliff around. I've always wanted to get one of his ECUs because they have techie cool factor :nerd: and I like to support quality homegrown..work. Guess I'll have to start saving my pennies. Thanks for the report Frank
J
Frank
The ECU case should have a ground wire at one of the mounting bolts. An intermittent brush of the +12V lead across the case really shouldn't fry the ECU - just make lost of pretty sparks and ruin your composure. I've actually had the same thing happen and the ECU still runs just fine. Statiscally then, we could say that an ECU failure only occurs 50% of the time when the case is brushed by the battery lead. Lousy odds. Note to self: Avoid doing this again. :blush:
Hi Rob,
Frank
61609[/snapback]
Did it come loaded with a MAP that closely matched your bike/modifications or does it come loaded with the stock MAP then it's up to the owner to make changes?
Not sure if you have worked with a Power Commander but I was wondering what the ease of modifing the MAP is compared to a PC which is a walk in the park.
Mike
Yeah, I don't know if it is my good luck, but I've done the same thing.... bridged to the ECU case by accident, with no ill effects(not that I'd recommend it).
The ground wire should help protect it.
I also am curious about the process to tune the MyECU to fit your particular setup.
Glad to hear it worked out well :thumbsup:
61666[/snapback]
You won't probably hear much, there is not much to tell. I bought a wideband probe, adjusted the O2-targets in the map, hit the auto-optimize button on the optimizer and started commuting as usual. Remember, the MyEcu is closed loop capable, so it's able to do it all alone, and it does so!
I can only backup what Frank said. It was fun from the first day I got mine.
Hubert
Cliff had a map in there for me and it has been running quite well.
He has some software to tune it, or you can tune it with notepad. It is a relatively small text file. The trick is you have to know what you are doing to make any improvements.
I’ve never used a PowerCommander. They don’t make one for the 2003 V11. But Cliff’s ECU adjustment options are much more comprehensive.
Here is the map it came with, but don’t ask me to explain it. I just call Cliff, and he tells me what to do:
Static Config TDC=0x1600, CylOffs=270, PulsesPer=48, MissingPulses=3,CoilCharge0=6000,CoilCharge1=2500, PSensor=0
My16M Config RPM=8620, O2=0.00V,0.55V,0.65V,0.70V,0.73V,0.78V,0.83V,0.86V, TPS=90
THR 960 896 832 704 640 576 512 448 384 320 256 192 128 64 0
RPM 500 1000 1322 1520 1750 2011 2314 2662 3059 3521 4045 4655 5353 6157 7082 8143
SpkAdv 14 5.16 11.95 18.05 20.39 21.33 22.03 23.44 25.55 28.13 26.95 28.13 33.28 35.16 35.16 35.16 35.16
SpkAdv 13 5.16 11.95 17.81 20.39 21.56 22.50 23.67 25.78 28.13 27.66 28.59 33.05 35.16 35.16 35.16 35.16
SpkAdv 12 5.16 11.48 17.81 20.39 22.03 23.44 24.38 26.02 28.36 28.83 29.77 32.81 34.92 35.16 35.16 35.16
SpkAdv 11 5.16 10.55 16.88 19.69 21.80 23.44 24.61 26.48 29.06 30.23 30.70 32.81 34.92 35.16 35.16 35.16
SpkAdv 10 5.16 10.08 16.17 18.75 21.09 22.97 24.38 26.72 29.53 30.70 30.70 33.05 34.92 35.16 35.16 35.16
SpkAdv 09 5.16 10.08 16.17 18.98 21.56 24.14 25.31 27.66 29.77 32.58 33.28 35.39 37.27 37.50 37.50 37.50
SpkAdv 08 5.16 10.08 16.17 18.98 22.27 23.20 25.31 27.66 29.77 34.22 35.86 37.73 39.61 39.84 39.84 39.84
SpkAdv 07 5.16 9.14 14.30 16.64 19.92 22.73 24.38 27.19 29.77 33.75 36.33 39.14 40.31 41.02 41.02 41.02
SpkAdv 06 5.16 7.03 12.19 14.53 17.58 20.39 22.97 26.48 29.77 34.69 38.91 40.78 41.72 42.66 42.66 42.66
SpkAdv 05 5.16 5.16 11.25 14.06 17.34 20.39 22.03 26.02 29.77 36.33 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 04 5.16 5.16 11.02 13.59 18.05 21.80 23.91 27.42 29.77 36.33 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 03 5.16 5.16 10.78 13.36 18.28 22.73 25.31 29.30 29.77 36.33 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 02 5.16 5.16 10.78 13.36 19.22 24.38 26.95 29.77 29.77 36.33 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 01 5.16 8.20 10.78 13.36 19.69 25.31 29.30 29.77 29.77 36.33 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 00 5.16 8.44 8.44 13.36 19.69 25.31 29.30 29.77 29.77 36.33 40.78 42.42 43.59 44.06 44.06 44.06
InjAdv 14 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 13 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 12 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 11 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 10 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 09 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 08 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 07 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 06 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 05 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 04 360 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 03 300 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 02 300 375 405 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 01 300 300 375 405 420 450 465 495 525 525 525 525 525 525 525 525
InjAdv 00 300 300 345 405 420 450 465 495 525 525 525 525 525 525 525 525
InjDur 14 4992 12464 12368 12304 12064 11856 11680 11440 11216 11504 11072 10928 11664 13024 12720 12384
InjDur 13 4992 12416 12320 12256 12016 11808 11648 11392 11152 11424 11040 10864 11504 12704 12400 12144
InjDur 12 4992 12336 12224 12144 11904 11696 11552 11296 11008 11232 10944 10720 11136 11952 11648 11616
InjDur 11 4992 12032 11888 11824 11664 11520 11312 11024 10720 10704 10208 9552 9632 9968 9600 9488
InjDur 10 4992 11808 11664 11600 11536 11472 11152 10848 10576 10368 9536 8960 9120 9264 8288 7872
InjDur 09 4992 10416 10304 10256 10160 10064 9824 9568 9312 9280 8688 6624 6992 7264 6896 6528
InjDur 08 4992 9024 8928 8880 8752 8640 8464 8256 8048 7648 6864 6320 5968 5792 5744 5168
InjDur 07 4992 9008 8736 8624 8528 8432 8208 8016 7856 7376 6256 5584 5584 5504 5440 5024
InjDur 06 4992 9088 8448 8192 8096 7984 7392 7072 6672 6320 5728 5088 5056 4928 4624 4880
InjDur 05 4992 8256 7792 7600 7312 7040 5952 6160 6016 5648 5184 4624 4528 4640 4192 3856
InjDur 04 4992 6496 6400 6352 6320 6080 5536 5312 5328 4992 4704 4272 4064 4208 4080 3632
InjDur 03 4992 5536 5392 5328 5312 5280 4464 4656 4704 4448 4240 3920 3776 3472 3360 3328
InjDur 02 4992 4992 4768 4752 4592 4320 4032 4096 4048 3872 3568 3264 3088 2944 3456 3280
InjDur 01 4992 4880 4528 4144 4000 3792 3456 3424 3152 2864 2640 2304 2080 1968 1920 1920
InjDur 00 4000 3600 3568 3264 2848 2704 2784 2592 2544 2448 2256 2256 2208 2256 1904 1728
CylOfs 14 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 13 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 12 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 11 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 10 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 09 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 08 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 07 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 06 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 05 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 04 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 03 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 02 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 01 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
CylOfs 00 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0 +0
Flags 14 (O0) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7) (O7)
Flags 13 (O0) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6)
Flags 12 (O0) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6)
Flags 11 (O0) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6) (O6)
Flags 10 (O0) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5)
Flags 09 (O0) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5) (O5)
Flags 08 (O0) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4)
Flags 07 (O0) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O4) (O4) (O4) (O4) (O4) (O4)
Flags 06 (O0) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O4) (O4) (O4) (O4) (O4)
Flags 05 (O0) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O4) (O4) (O4) (O4) (O4)
Flags 04 (O0) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O3) (O4) (O4) (O4) (O4) (O4)
Flags 03 (O0) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O3) (O3) (O4) (O4) (O4) (O4) (O4)
Flags 02 (O0) (O5) (O5) (O5) (O5) (O0) (O0) (O0) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4)
Flags 01 (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O4) (O4) (O4) (O4) (O4) (O4) (O4) (O4)
Flags 00 (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0) (O0)
#Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110
Prime 30 30 30 25 20 15 10 9 8 7 6 4
Crank 80 70 50 45 40 30 25 20 15 10 10 10 10 10 10 10
I forgot to answer Al's question.
I started with Clliff's map, and that was a huge improvement. Then I started riding. I did find a little rough spot at around 5100-5600 so he walked me through making 2 additional maps. One slightly leaner in that range and one slightly richer. Tomorrow I'll plug the bike into the computer an upload one of the new maps and go for a quick ride and see if it is better or worse.
BTW: Before I really didn't like the way the engine felt above 5-6000 and so I tended to keep the RPM low. Now it really feels great revving up in the 6000 area. I am finding I am running the same roads 1 or 2 gears lower that before, and the power delivery is SUPER quick. I've never played with an ECU before and I am amazed how it changes the whole feel of the bike. When I bought the Ducati I kinda shifted my preference away from the Guzzi, but now the V11 can really give the Duc a run for her money. Makes me wish I had 2 butts so I could ride them both at once, and not have to choose. :P
Of course they make PC's for the 03 V11's.
All year V11 sports have the same ECU.
like I stated in an earlier post, just the maps will be slightlly different for the newer models. (but anything seems to be an improvement in many V11's)
Closed loop systems for motorcycles are not perfect by any means, but I hope it works well for you. Cliffs system seems to do so.
Hi John,
Go to their web site and look. Or call them, I did.
Here is their fitment chart from
http://www.powercommander.com/buynowbike.shtml
Moto Guzzi
2004-2005 Breva 750 722-411 — — —
2000-2001 V11 Sport 706-411 — — —
2000-2001 California Special 707-411 — — —
2000-2003 Jackal / Bassa / Stone 708-411 — — —
2000-2001 Quota 1100 ES 709-411 — — —
2004-2005 Breva 1100 724-411 — — —
Frank
Yes, I'm well aware of the fitment chart that needs updating.
Guzzi's are such low volume for them, (virtually nil) they barely pay attention.
I am an authorized Power Commander dealer/Tuning Link Center and Certified PC tech Dyno shop owner. (250i)
I have Power Commanders fitted and running on 03 Lemans, and 04 Cafe sports with super results. Individual cyl. mapping does wonders for these bikes.
Guess I'll have to pester DynoJet to update the Guzzi (and Ducati,MV Augusta) site.
P.S, The Power Commander will fit ANY Guzzi running the 15m computer, Cruisers and sport bikes, Just the maps differ.
61721[/snapback]
John,
I sent you a PM.
Mike
