big J Posted October 8, 2005 Share Posted October 8, 2005 Can anyone out there confirm what bearings go in the steering head, mine are shagged. Dont want the old girl off the road any longer than necessary so I'll get new ones first and swap em over. It looks like ??205 on the top one. Presumably top and bottom are the same. Link to comment Share on other sites More sharing options...
dlaing Posted October 8, 2005 Share Posted October 8, 2005 I don't know if this helps, but the top and bottom are the same number: EDIT Here is a great chart intended for older Guzzis, but the part cross refs with what Pete and Paul said. http://www.users.tsn.cc/rdd/TT/contents/PRTS/partsub.html Link to comment Share on other sites More sharing options...
Paul Minnaert Posted October 8, 2005 Share Posted October 8, 2005 30205 is writen on mine. Link to comment Share on other sites More sharing options...
big J Posted October 8, 2005 Author Share Posted October 8, 2005 Thanks, lads. Link to comment Share on other sites More sharing options...
pete roper Posted October 8, 2005 Share Posted October 8, 2005 Yup, #30205, all Guzzi big blocks since the dawn of time have used the same boring as batshit bearing, they'll cost you about $8 at the local bearing factor. Pete Link to comment Share on other sites More sharing options...
Baldini Posted October 10, 2005 Share Posted October 10, 2005 ...mine are shagged.... BigJ - do you what caused bearings to fail - they haven't got many miles? KB Link to comment Share on other sites More sharing options...
Guest Nogbad Posted October 11, 2005 Share Posted October 11, 2005 Pulling wheelies perhaps....... Link to comment Share on other sites More sharing options...
big J Posted October 11, 2005 Author Share Posted October 11, 2005 Bloody corrugated Irish roads, I reckon. That's every wheel bearing been replaced and now the steering head. Ach well, could be worse. I did check the rear spacer and it measured up ok, so either poor initial dealer maintainance or the road surface. You've seen the roads here yourself, so I can't complain. Link to comment Share on other sites More sharing options...
Guzzirider Posted October 11, 2005 Share Posted October 11, 2005 Yep my steering head bearings were loose when I got back from a lap of Ireland- worse place was the south west- lovely scenery but bumpy as fook. Guy Link to comment Share on other sites More sharing options...
big J Posted October 16, 2005 Author Share Posted October 16, 2005 Dropped out the yokes, bottom bearing nothing more than a ball of rust. The nearest this thing ever got to grease was geographically,when it was in Italy. Btw, changed the fork oil at the same time, took off the top caps and flipped the legs and let them drain, refilled with 20w( all the shop had in ) not recommended, feels like I'e got two broomhndles for fork legs. I'll change it next week for 10- or maybe 5w Link to comment Share on other sites More sharing options...
guzzi323 Posted October 16, 2005 Share Posted October 16, 2005 Even though they are often under greased at the factory, I've always felt that the nature of the loads placed upon these is the largest cuprit in their early demise. Since all of the hard load bearing they do (hard braking, and for some folk coming down from wheelies ) usually has the front wheel straight, there's just no way for them to deal with it long. I replaced mine when I was replacing fork seals sometime around 20K miles. When I had the forks off doing the seals, I could feel a little bit of wear with the steering bearings. I've found that I rarely get 30K miles out before I start noticing them and since it was mostly apart I just went ahead and did them. johnk Link to comment Share on other sites More sharing options...
jrt Posted October 16, 2005 Share Posted October 16, 2005 I did check the rear spacer and it measured up ok, so either poor initial dealer maintainance or the road surface. You've seen the roads here yourself, so I can't complain. 62787[/snapback] Well, at least you know they're greased now. BTW, what did your rear spacer measure up to? Link to comment Share on other sites More sharing options...
big J Posted October 16, 2005 Author Share Posted October 16, 2005 Sorry,jrt, dont recall off hand. I measured the gap,checked the spacer was close enough and belted in the new bearings. Link to comment Share on other sites More sharing options...
