dlaing Posted October 11, 2005 Share Posted October 11, 2005 I digested most of the spaghetti, but lost it when it came to what was holding my stomach down...I mean, when it came to what was holding it in gear, and I don't have any more beer to wash the taste out I also have a disagreement with the anchovies, I mean the concentric adjuster. It is not a limiter, as first impressions indicate. It holds the pawl arm in perfect equilibrium, or not, between the opposing spring forces, kind of like the balance of nausea and euphoria of a binge. Link to comment Share on other sites More sharing options...
belfastguzzi Posted October 11, 2005 Share Posted October 11, 2005 Well said sir. It may have all been a bad dream. Link to comment Share on other sites More sharing options...
belfastguzzi Posted October 11, 2005 Share Posted October 11, 2005 Do you think I could pass it off as an original Guzzi wiring diagram? The fact that the description is probably all wrong can only enhance its credibility. I could flog it on Ebay to new Guzzistas, sucked in by the Breva and now looking for some memorabilia from the good old days. Link to comment Share on other sites More sharing options...
BrianG Posted October 11, 2005 Share Posted October 11, 2005 If we are keeping count of this "rare" anomaly, I have this same issue on my 2000 V-11 Sport. Same fix, too by the way! Link to comment Share on other sites More sharing options...
dlaing Posted October 12, 2005 Share Posted October 12, 2005 Do you think I could pass it off as an original Guzzi wiring diagram? The fact that the description is probably all wrong can only enhance its credibility. I could flog it on Ebay to new Guzzistas, sucked in by the Breva and now looking for some memorabilia from the good old days. 62781[/snapback] Your English is too good to be orignal factory Guzzi techno writing: So here, I re-wrote (actually google translated) a bilingual translation for you to enhance it herewith: La leva dell'ingranaggio gira questo pllate che il patè tira il bac del braccio del dentarello ed avanti che gira l'anello del seeger che sposta le forcelle del selettore sugli alberi di ingranaggio che determina quanto lontano questa piastra si muove. È fissata al braccio malfamato del dentarello del preselettore strette di questo lad esso ingranaggio di i o nel neutrale e può sedersi nel fratempo in un neutrale falso. The lever of the gear turns these pllate that the patè it pulls the bac of the arm of the dentarello and ahead that turns the ring of the seeger that moves the staples of the selector on the gear trees that determine how much far away this slab move. Gear of or in the neutral one is fixed to the malfamato arm of dentarello of the preselector tight of this lad it and can be based in the fratempo in neutral a false one. Link to comment Share on other sites More sharing options...
belfastguzzi Posted October 12, 2005 Share Posted October 12, 2005 The lever of the gear turns these pllate that the patè it pulls the bac of the arm of the dentarello and ahead that turns the ring of the seeger that moves the staples of the selector on the gear trees that determine how much far away this slab move. Gear of or in the neutral one is fixed to the malfamato arm of dentarello of the preselector tight of this lad it and can be based in the fratempo in neutral a false one. 62875[/snapback] Fab. At least the guys from Northern England will understand now. I was tempted to do the same with the Robert Peel speech last week, but wasn't sure what language to use Link to comment Share on other sites More sharing options...
antonio carroccio Posted October 27, 2005 Share Posted October 27, 2005 Same problem here buddies.... Should I try to fix it? <_> Link to comment Share on other sites More sharing options...
dlaing Posted October 27, 2005 Share Posted October 27, 2005 Same problem here buddies....Should I try to fix it? <_> 64819[/snapback] What?, too much Pasta? Link to comment Share on other sites More sharing options...
antonio carroccio Posted October 27, 2005 Share Posted October 27, 2005 gearbox my friend, gearbox! You have got to much pasta, spaghetti in your head... Link to comment Share on other sites More sharing options...
Troy Posted August 19, 2006 Share Posted August 19, 2006 If I remove the cover, I assume I need to clean the mating surfaces and apply new sealant. Is Permatex Hylomar HPF OK or is there a better choice when reinstalling the cover? I just made it to 100 miles and feel the urge to check for the correct 15mm boss and to change to Redline. Thanks, Troy Link to comment Share on other sites More sharing options...
belfastguzzi Posted August 20, 2006 Share Posted August 20, 2006 If I remove the cover, I assume I need to clean the mating surfaces and apply new sealant. Is Permatex Hylomar HPF OK or is there a better choice when reinstalling the cover? I think that any sort of sealant will do. I've used various, including 30 year old (or thereabouts) Golden Hermitite, which I would use again. Last time that I had the cover off it was by the roadside, so I put it back together without any sealant at all. It's still like that and has been ok. Try a smear of blue instant gasket. Or Permatex Hylomar HPF – whatever that is. Link to comment Share on other sites More sharing options...
Ouiji Veck Posted August 22, 2006 Share Posted August 22, 2006 I investigated my selector spring and it looked free through the gears @ 8K mi. Ordered a spring...it lives in my tank bag. After inspecting the spring the cover went back on with the adjuster out of whack...poor downshifting. I was able to use a bisected 19mm wrench and adjust it on the fly. The bisected wrench, spare spring and thier little baby ground down allen wrench all live hapilly togeather in county tank bag in the village of tool bag... All this during my honneymoon days with the LeMans. 23K mi now and my tool bag looks more like something a witch doctor would carry. All I need now is a bat wing and some goat blood and I can take this thing anywhere,..... Link to comment Share on other sites More sharing options...
Lamedog Posted August 22, 2006 Share Posted August 22, 2006 Thanks all! Same symptoms sprung up for me over the past week. Recently added the Buell pegs and presumed I'd screwed up the adjustment. This by shortening the threaded-end connecting rod until the lever position seemed OK. Throw range seemed unaffected by the few turns I took up. First thought was the sloppy shifting symptoms occurred after, now I'm thinking they started before and have been degrading quickly (in spite of the Redline shockproof heavy). I'll try this fix over the weekend. Link to comment Share on other sites More sharing options...
jrt Posted August 22, 2006 Share Posted August 22, 2006 Try a smear of blue instant gasket. Or Permatex Hylomar HPF – whatever that is. It's good stuff- my current favorite general sealant because it is non-hardening and seals very well. Link to comment Share on other sites More sharing options...
belfastguzzi Posted August 22, 2006 Share Posted August 22, 2006 It's good stuff- my current favorite general sealant because it is non-hardening and seals very well. I looked at the Permatex website. Grief: what-a-lotta-sticky stuff! Link to comment Share on other sites More sharing options...
