Guest mcloutier Posted March 11, 2003 Posted March 11, 2003 I have seen a lot of negative comments about K&N single pods on F.I. bikes on other sites/lists. I know that I will have to adjust the a/f ratio but I allready have a PC3. I also know that I will need to fabricate a velocity stack to keep the air flow smooth. I really love the look and sound of the pod filters. Any one have any real world experienace with pods on their Le Mans? Thanks,
Guest jeremy Posted March 11, 2003 Posted March 11, 2003 I use pod filters on my centauro, they work well, and I just removed the stock velocity stacks from the air box and used those because they are close to the correct lenght from the factory and slipped the pods over them. I used UNI filters though. Trust me though the intake makes ALOT more noise without the airbox! Gained a couple of HP also
jrt Posted March 12, 2003 Posted March 12, 2003 Ditto. I've got them on my V11 sport. I've no complaints about the conversion and I don't have a PCIII. It also opens up the mid-section of the bike, because you have to remove the side panels. I dig the cheese smile... Jason
jtucker Posted March 14, 2003 Posted March 14, 2003 I believe I used the RU-0600 model K&N - did not fab velocity stacks, per se, but I yanked the intakes out of the airbox, trimmed off the flared end, and mounted the filters to that. Works well.
