Have anybody used the new K&N oil filter? It has a built-in nut. I'm not sure if we have clearance for that nut. The K&N filter was about 1/2" to 3/4" longer than the Fram filter. The K&N unit was much heavier and looked to have better build quality. The K&N was $9.99 as compared to the $4.99 Fram. I would pay extra for the K&N but need to know if it will fit (lengthwise). If you have used this filter, please reply with the needed info.
the factory filter wrench,
I bought the ' factory filter wrench' for some high price. When supplied it did not have the hex drive to remove the access plate to the filter. I have found the rear axle nut to be the correct size to remove the plate.
