v11 oil leaks @ spine lines and plugs
Guest SFGUZZI
Hey All.
just a titbit of info,my v11 had the cronic oil leak from the breather union and plug bolt,i installed Land Rover part number STC1950 washers with rubber seals inside and stopped the leaks instantly,not sure if anyone knows about this but the fit and the sealing quality are superb
Just my :2c:
I've not seen that suggestion before- thank you for it. If you send it to Greg Field (that's also his user name here), he might include it in the tips section of the MGNOC.
66042[/snapback]
I've got a few suggestions for you, that you haven't seen before.
66045[/snapback]
Do any of them involve ointment?
So, Greg, does that mean there's another book in the works? Very much enjoyed the first! :thumbsup:
Hey All.
Just my  :2c:
66024[/snapback]
Where is the "breather union and plug bolt your referring to?
Mike
Mike
66245[/snapback]
Glad you asked, I was wondering too. Is chronic leaking from one of the banjo unions a general problem? Which one?
What are they,Dowty washers?
Using Landy parts to fix your bike :D
Landy owners usually cannibalise other vehicles to keep theirs on the road. :P
Guest SFGUZZI
66248[/snapback]
Belfast...
its the Banjo fitting located on the right side of the spine,actually the breather drain line to the sump,the left side of the spine has a blanking plug,also a leak issue
SF
Guest SFGUZZI
Belfast...
SF
66266[/snapback]
Sorry all got it backwards drain line on left ,blanking plug on right..!!!!!!
SF
Thanks. With my bike doing a lot of short journeys, I get a lot of water sitting in there. I took the banjo off and looked in through the socket on the left. I didn't look at the right side and didn't realise that there is a plug there. Maybe it would be good for draining the water out?
What are the Land Rover parts for, originally?
Guest SFGUZZI
66271[/snapback]
They fit late model 4.6l Range Rover power streering hose banjo(pressure side)
SF
I remember Pete saying there is a PCV valve. I can't find it on mine.
Where is it?
