beauchemin Posted November 14, 2005 Posted November 14, 2005 Does anyone know what grade of stainless steel that the exhaust headers are made of?
Steve G. Posted November 14, 2005 Posted November 14, 2005 Does anyone know what grade of stainless steel that the exhaust headers are made of? 67213[/snapback] I've been thinking the same thing Chris. The S.S. used is different from the quality of Staintune. Ciao, Steve G.
helicopterjim R.I.P. Posted November 14, 2005 Posted November 14, 2005 I've been thinking the same thing Chris. The S.S. used is different from the quality of Staintune. Ciao, Steve G. 67214[/snapback] It seems similar to Mistral parts but different than Stucchi as well.
beauchemin Posted November 14, 2005 Author Posted November 14, 2005 I want to know so that I can get some WB02 sensor fittings made from the same material (or at least very similar).
dlaing Posted November 14, 2005 Posted November 14, 2005 fwiw Staintune uses 304 grade stainless steel So, I guess it is not that...
moto Posted November 17, 2005 Posted November 17, 2005 I want to know so that I can get some WB02 sensor fittings made from the same material (or at least very similar).67218[/snapback] Use a 304 bung and weld it on with 308 rod. Be sure to back purge with argon. If you can't find a bung with a radius to match the OD of the pipe, I can machine one for you. Regards, Derek
