Guest ratchethack Posted November 24, 2005 Posted November 24, 2005 My memory's a little sketchy here, but I think the plunger has a concavity that accepts the ball bearing. It should be obvious, but obviously , it's not. One part I distinctly recall is having to use a little grease to retain the ball when assembling. Don't know what you mean by misaligned??
Guest SantaFeRider Posted November 24, 2005 Posted November 24, 2005 Yep. No. My memory's a little sketchy here, but I think the plunger has a concavity that accepts the ball bearing. It should be obvious, but obviously , it's not. One part I distinctly recall is having to use a little grease to retain the ball when assembling. Don't know what you mean by misaligned?? 68588[/snapback] then I must have lost the concave end of the plunger... do you think I can buy the piece or do I have to buy a whole new master cylinder? without the concave piece, when you force the plunger against the ball, the plunger goes to one side...
Guest ratchethack Posted November 24, 2005 Posted November 24, 2005 Sorry SantaFeRider. A memory is a terrible thing to lose. I just went out and disassembled and re-lubed my bar levers to get re-acquainted with 'em. Your post was the inspiration - thanks. New lube didn't hurt a thing. The ball bearing doesn't go where you've got it in your photo. It goes in a hole inside the lever carrier, where it pushes on the brake microswitch when the lever is released, opening the brake light circuit. Without the ball in there, the switch will never open and your brake light will always be on. BTW - On the clutch side, instead of a ball bearing, there's a cylinder-shaped puck that looks to be the same diameter as the ball bearing. It works the same way with the clutch switch. ALSO - The slotted screw is NOT an adjustment for the brake light switch as I said previously. This is for adjustment of the brake master cylinder plunger. Mine's still sealed with some factory sealing goop. I can't think why this would ever need adjustment unless you installed a new master cylinder. At least I'd correctly remembered the part about using grease to hold the puck and ball in place for re-assembly.
Guest SantaFeRider Posted November 25, 2005 Posted November 25, 2005 thank you ratchethack. After all the turkey and wine ingested, I am going to leave the thinghie until tomorrow. I will remove the brake lever and hope I can see that hole where the ball goes. You have been very helpful; riding around without the possibility of telling others when you apply your brakes is not advisable.
grossohc Posted November 25, 2005 Posted November 25, 2005 Santa fe rider, you do not remove the brake lever, just remove the micro switch and you will see where the ball has to go on the lever holder, just put it in and refix the switch so it is against the ball thats all i did when i lost mine ball Gary
mdude Posted November 25, 2005 Posted November 25, 2005 ALSO - The slotted screw is NOT an adjustment for the brake light switch as I said previously. This is for adjustment of the brake master cylinder plunger. Mine's still sealed with some factory sealing goop. I can't think why this would ever need adjustment unless you installed a new master cylinder. 68592[/snapback] I had to adjust this inwards by a full 1 1/2 turn on my bike. The brake lever didnt do anything useful before it almost met the gashandle, and the brakes were mushy. Dont know why it was lkike that in the first place. The screw can be useful if the driver has tiny hands, maybe?... It might be a small air problem in there somewhere (going to service the brakes in spring), but now the handle is firm and positive and the brakes bite early. The screw was not sealed with goop, as you explain, and no sign of goop is to see. The clutch handle screw has some goop in it. And come to think of it, so has I...
DeBenGuzzi Posted November 26, 2005 Posted November 26, 2005 They should last for ever! Hubert 68568[/snapback] know where I can get one of those flashy LED's and how hard of an Install are we talkin? plug and play or rewire
Guest SantaFeRider Posted November 26, 2005 Posted November 26, 2005 well... I must be a useless twat, because I can't figure where the ball goes and the shop manual which cost me over $ 80 does not show it
DeBenGuzzi Posted November 26, 2005 Posted November 26, 2005 Secondly if I ever come across somewhere to get the proper BB that guzzi uses and I'll buy the whole box and send them to ppl for Free if they ask nicely.
Guest SantaFeRider Posted November 26, 2005 Posted November 26, 2005 well... I finally found a schematic of the front brake. 3 is the devilish ball and 5 is the microswitch. There are two very fine vertical screws seemingly holding the microswitch to the lever holder. I will try to remove the microswitch and see if there is a hole or channel to receive the ball.
Guest ratchethack Posted November 26, 2005 Posted November 26, 2005 I can't figure where the ball goes FWIW, if I squeeze the brake lever firmly, by directing a light, I can just see the ball coming into view in its hole through the space between the lever and the lever carrier. Sort of an annoying little , ain't it?
Guest SantaFeRider Posted November 26, 2005 Posted November 26, 2005 now you confused me my friend. Should I remove the lever to insert the ball in its hole or should I remove the microswitch?
Guest ratchethack Posted November 26, 2005 Posted November 26, 2005 You can do it either way, but I think it's less tedious to take the lever out.
Guest SantaFeRider Posted November 26, 2005 Posted November 26, 2005 FWIW, if I squeeze the brake lever firmly, by directing a light, I can just see the ball coming into view in its hole through the space between the lever and the lever carrier. Sort of an annoying little , ain't it? 68688[/snapback] once you know where the ball goes it's easy. Now, this is annoying, because you have to do this for everything but draining the oil
Guest ratchethack Posted November 26, 2005 Posted November 26, 2005 Looks pretty annoying alright. But do you find tiny leftover parts on the floor afterward?
