ALLAN Posted November 30, 2005 Posted November 30, 2005 I AM IN DESPERATE NEED OF A COMPLETE HEADLAMP ASSEMBLY, P/N 32740510, FOR MY 2004 LEMANS. HELP!! Allan
Guest motomaniac Posted November 30, 2005 Posted November 30, 2005 I'm not familiar with the LeMans assembly, but, I do have a headlight assembly off of my 2004 Ballabio. It is the frame mount as shown in this pic: http://www.v11lemans.com/forums/index.php?...pe=post&id=1923 http://www.v11lemans.com/forums/index.php?...pe=post&id=1924 Also, the top pic here: http://www.v11lemans.com/forums/index.php?...pe=post&id=2225 If this matches what you need let me know and we'll work something out.
Guzzirider Posted November 30, 2005 Posted November 30, 2005 Try Pete at Reboot spares http://www.rebootguzzispares.com/index.html?mainframe.htm&2 He has broken a V11 Le Mans and may have a headlight. It will probably be British spec but if you have your old headlamp you can change the beam reflector around although its a bit of a pain in the arse. Guy
Ballacraine Posted December 1, 2005 Posted December 1, 2005 Rosso Andy said that the actual glass and reflector is identical to the one used on one of the recent / current naked BM's. I realise we are comparing naked with faired, but it may be worth looking into? Perhaps the whole headlamp asembly may be compatible? Nige.
ALLAN Posted December 1, 2005 Author Posted December 1, 2005 I'm not familiar with the LeMans assembly, but, I do have a headlight assembly off of my 2004 Ballabio. It is the frame mount as shown in this pic: http://www.v11lemans.com/forums/index.php?...pe=post&id=1923 http://www.v11lemans.com/forums/index.php?...pe=post&id=1924 Also, the top pic here: http://www.v11lemans.com/forums/index.php?...pe=post&id=2225 If this matches what you need let me know and we'll work something out. 69126[/snapback] THE HEADLAMP APPEARS IDENTICLE. LET ME KNOW WHAT YOU WANT FOR IT. THANKS.
