Hi,
Anybody know the factory settings for the WP upside down fork for a 1997 Sport 1100i ?
The owners manual states settings for the rear damper, but nothing for the fork.....
/Jens
www.guzzitech.dk/english
Umm depends on how you ride how much you wiegh what your springs are like. Best thing is to count the numer of postions and put the compression in the middle with say the rebound two steps tighter.
Write down where you are at go for a ride on a known road and work out it it need to be tighter or softer then go quarter of the total adjustments on both towards where you think it should go. Important to keep track of where you are at repeat the ride and then decide which way it needs to go then go one eigth of the total adjustments. Ie if say there was 28 total adjustments you would start at around 14 then move 7 "clicks" then 3 or 4. Repaeat this process till you have it where you are happy.
However if you are seriously over 75kg you will probally need to look at respringing the front end to suit. A static sag measurement will tell you if this is neascary the dampening will never really work properly if the springs are wrong.
