Guest corsahack Posted December 30, 2005 Share Posted December 30, 2005 I am having problems with a very rough running 98 Corsa. I have done all the checks described on the forum with one exception... Replacement chip. When I get one what do I do with it and where does it go?. The corsa has its original set up and I am willing to give it a go unless the advice is dont bother, take it to a dealer. Over to you wise ones. Link to comment Share on other sites More sharing options...
Guzzirider Posted December 30, 2005 Share Posted December 30, 2005 Its easy from what I can remember: Make sure your ignition is off and the key in your pocket Remove drivers seat Peel back sticker on black box that says do not remove- you can reseal this afterwards Take off cover from the top of black box Remove old chip carefully- you may need a chip puller but you can probably do without Make sure legs are nice and straight on new chip Carefully fit new chip in the holes left by the old one If you are fitting a WPC12 Creedon chip (which used to be the best for the Corsa- was for me anyway) use a screwdriver to adjust the mixture screw which is on the same circuit board (if I remember correctly) to its richest setting. Put the cover back on Reseal the sticker Put the seat back on Ride and enjoy Guy Link to comment Share on other sites More sharing options...
Alex-Corsa Posted December 30, 2005 Share Posted December 30, 2005 I am having problems with a very rough running 98 Corsa. I have done all the checks described on the forum with one exception... Replacement chip. When I get one what do I do with it and where does it go?. The corsa has its original set up and I am willing to give it a go unless the advice is dont bother, take it to a dealer. Over to you wise ones. The workshop manual on page 112 shows the position of the chip. There are different chips for the corsa , If you like email me for more details about what and how to do, plus what chips exist and performance... Link to comment Share on other sites More sharing options...
Guest corsahack Posted December 30, 2005 Share Posted December 30, 2005 Its easy from what I can remember: Cheers, I will send off for one and let you know. Who knows it might even work. Link to comment Share on other sites More sharing options...
Guest corsahack Posted December 30, 2005 Share Posted December 30, 2005 The workshop manual on page 112 shows the position of the chip. There are different chips for the corsa , If you like email me for more details about what and how to do, plus what chips exist and performance... I have the manual you sent me and I am about to amend my profile with my new @ mail address. Thanks for all the advice. Link to comment Share on other sites More sharing options...
Alex-Corsa Posted December 30, 2005 Share Posted December 30, 2005 I have the manual you sent me and I am about to amend my profile with my new @ mail address. Thanks for all the advice. I have experimented with some chips lattely.ANd have made an occational dyno measurmants on varios configurations.I am having a more in depth look to this subject mostly for 2 reasons. a) I want to know what's goin on on my bike b)Having the option to really construct chip configurations that fit as good as it should be for the set ups and the road use I like to do. Link to comment Share on other sites More sharing options...
