scre103 Posted December 31, 2005 Posted December 31, 2005 i would like to grease the shaft on my rosso, how do i get to all the grease zerks. the locations are illustrated in the owners manual however the zerk located near the engine is difficult to reach. any tips or thoughts. does my bike have to be up on a stand to reach all the zerks? thanks scre happy new year
Ouiji Veck Posted December 31, 2005 Posted December 31, 2005 Oh boy....here we go... The forward zerk is a tough one... I get mine @ tire change time...and use a "needle" tip on the grease gun. The regular "fat" tip just wont get in there...most have found an "angeled" tip that works for them...not me. Good luck..
BrianG Posted December 31, 2005 Posted December 31, 2005 A die grinder gently applied to the u-joint cage looks to be the answer.
scre103 Posted December 31, 2005 Author Posted December 31, 2005 A die grinder gently applied to the u-joint cage looks to be the answer. 72612[/snapback] great idea brian, why didn't i think of that!!!!
Guest Nogbad Posted December 31, 2005 Posted December 31, 2005 Is the U Joint cage essential? Why not simply bin it and enjoy better access. Just don't wear frayed jeans or lace up shoes.
BrianG Posted December 31, 2005 Posted December 31, 2005 Is the U Joint cage essential? Why not simply bin it and enjoy better access. Just don't wear frayed jeans or lace up shoes. 72666[/snapback] I'd probably get my finger caught!
rossoandy Posted January 1, 2006 Posted January 1, 2006 great idea brian, why didn't i think of that!!!! 72642[/snapback] yeah know just wat you mean...guess best route is to remove rear wheel and bevel box? let shaft hang down so joint opens right up and grease gun will fit. luv my rosso.....
Frank Posted January 2, 2006 Posted January 2, 2006 Guys, This is what I use. I got a long, 16 inch or so grease gun extension hose and bought the following from McMaster-Carr: 1090K47 . I did have to drill out the hole on this item to fit the grease nipple but it works great. http://www.mcmaster.com/
scre103 Posted January 2, 2006 Author Posted January 2, 2006 yeah know just wat you mean...guess best route is to remove rear wheel and bevel box? let shaft hang down so joint opens right up and grease gun will fit.luv my rosso..... 72691[/snapback] rossoandy,you have your rosso posted as a 2000,did the rosso come to the uk in 2000, my rosso here in the usa is a 2001 model. scre
leafman60 Posted January 7, 2006 Posted January 7, 2006 Good grief, there's an old thread on this topic. Its an easy task once you have the correct utensils. go to Ace hdw or etc and get a hinged/swivel grease head. I affixed that to a 1/8" extension pipe nipple. you then approach the front grease fitting for the rear of the bike (have the universal joint fitting rotated up). After youve done it a time or two, its a piece of cake, takes maybe 2 minutes, no wheel removal or anything. "Try it, you'll like it."
Guest trispeed Posted February 4, 2006 Posted February 4, 2006 Hello all, the 2004 models must be different. The only access was after bending the needle nose style; even the rearmost U- joint fitting was inaccessible without this. BTW, the rear splines were COMPLETELY dry; I have only 1900 miles! Glad I had to change tires already!!
Morris Sod Posted February 25, 2006 Posted February 25, 2006 Hey I've finally done it. Greased the front grease nipple in drive shaft. A local mechanic leant me his right angle grease gun head. ie has normal head for attaching to nipple or zerk and rear end has another grease nipple to attach to gun. Definitley need to remove rear wheel and let drive shaft drop to lowest point and only then can you just get the grease head to attach. 3 pumps before first sign of grease appeared, so methinks this job had been overlooked at dealers service. Wot I would like to know is how often do they need servicing, every 10K km, 25k km, what does the book say?
Steve G. Posted February 25, 2006 Posted February 25, 2006 Hey I've finally done it. Greased the front grease nipple in drive shaft. A local mechanic leant me his right angle grease gun head. ie has normal head for attaching to nipple or zerk and rear end has another grease nipple to attach to gun. Definitley need to remove rear wheel and let drive shaft drop to lowest point and only then can you just get the grease head to attach. 3 pumps before first sign of grease appeared, so methinks this job had been overlooked at dealers service. Wot I would like to know is how often do they need servicing, every 10K km, 25k km, what does the book say? 80031[/snapback] I think the manual says 20,000kms. And you are right, taking the rear wheel off and lowering the shaft make it easy. Ciao, Steve G.
bigbikerrick Posted February 25, 2006 Posted February 25, 2006 I just finished doing mine at tire change also took apart the cush hub, replaced the shitty button head allens with some real bolts with deeper heads, the cush hub sleeve was dry, and the splines had hardly any grease, With the shaft dropped to its lowest point, the grease nipple pops right on, Good Luck.
Guest ratchethack Posted February 25, 2006 Posted February 25, 2006 A heads-up move on the cush drive hub collar, Rick! I expect this preventive maintenance'll be greatly appreciated by y'er Guz! She may even love you back! Y'er ol' man's wisdom's well applied here, IMHO.
