I'm definitely interested to hear how that turns out, although I don't have any suggestions for you. Good luck with the conversion, please let us know what you find out!
I was considering this HID direct replacement for the H4
http://www.itsrealstuff.com/html/motorcycl...cle_h_i_d_.html
$499
http://www.coolbulbs.com/HIDKits_body.asp
$579 US
Make sure you get the High/Low beam
http://www.webbikeworld.com/lights/index.htm#list
has links to other HID vendors.
The Prices of HIDs is high and may come down in a couple of years.
I was even thinking of getting a pair of Bicycle HID lights but I suspect the beam patterns might not be suitable.
A pair of HID driving lights is another option...
Last I head, HID was under investigation by the DOT to be de-legalized. Power requirements are probably quite a bit in excess of what the bike can supply anyway.
Guest carlomoto
I looked at HID, too. The cost was more than I could swallow, so I just bought a PIAA super bright. MUCH brighter. The blue-ish color of the bulb gives the headlight an interesting look against the rest of the bike as well. Good luck on the conversion.
/Charlie
Guest jeremy
Which model honda was it, I'd like to do something similar if it works out, after hitting a deer on my bike last fall I've been sort of paranoid. :bier:
