dangerous Posted January 10, 2006 Share Posted January 10, 2006 Ok.... the bolt is easy nuff.... but how do the fuel conectors release??? Bloody hand book shows how to remove the air filter..... but not the tank So are the 2 fandangle conectors quick release and have a self closing cock (no fuel spilage) or do I need the bolt cutters Link to comment Share on other sites More sharing options...
waspp Posted January 10, 2006 Share Posted January 10, 2006 No bolt cutters needed, just a swear jar! Grab the grey ring and pull it towards the fuel line away from the tank, that usually works for me. You can also put slight pressure holding the line back towards the tank while pulling the grey ring away from the tank. Actually they work pretty well once figured out. Hal Link to comment Share on other sites More sharing options...
dangerous Posted January 10, 2006 Author Share Posted January 10, 2006 Awesome..... thanks thought it was a easy as that but Knowing my luck I bust it if I dident ask 1st. Link to comment Share on other sites More sharing options...
Mike Stewart Posted January 10, 2006 Share Posted January 10, 2006 Be careful when removing the lines, there still could be fuel pressure in the lines. Have a rag ready and perhaps eye protection. I push the fuel line toward the tank and pull the gray connector toward the line, the line will slide right off. Mike Ok.... the bolt is easy nuff.... but how do the fuel conectors release???Bloody hand book shows how to remove the air filter..... but not the tank So are the 2 fandangle conectors quick release and have a self closing cock (no fuel spilage) or do I need the bolt cutters 73894[/snapback] Link to comment Share on other sites More sharing options...
coz1100 Posted January 10, 2006 Share Posted January 10, 2006 Be careful when removing the lines, there still could be fuel pressure in the lines. Have a rag ready and perhaps eye protection. I push the fuel line toward the tank and pull the gray connector toward the line, the line will slide right off. Mike 73901[/snapback] I've always found it helpfull to run the bike till it runs dry after you shut the fuel valve. Link to comment Share on other sites More sharing options...
Greg Field Posted January 12, 2006 Share Posted January 12, 2006 If it has the tank-mounted pump, be extra careful that you do not break off the right-angle plastic spigots that exit the tank. These are part of the pump assembly and are not available separately. Link to comment Share on other sites More sharing options...
Mike Stewart Posted January 12, 2006 Share Posted January 12, 2006 Unfortunately there is no fuel shut off valve on the 03 bikes, the fuel pump is inside the tank. Even if you did pull the fuel pump fuse or relay and ran the bike until it died, there could still be residual fuel pressure in the lines. Also best to pull the lines when the motor is cool. Mike I've always found it helpfull to run the bike till it runs dry after you shut the fuel valve. 73933[/snapback] Link to comment Share on other sites More sharing options...
coz1100 Posted January 13, 2006 Share Posted January 13, 2006 ahh, noted. Mines an 02 so I just have the screw in petcock. Link to comment Share on other sites More sharing options...
