Guest SoCalDon Posted February 12, 2006 Posted February 12, 2006 Liquid Cooled 4 Valve DOHC 103HP@8000rpm 9.4Kgm@6500rpm See the curves here; http://www.engines.piaggio.com/bank/3/124.pdf So, what do you figure their puting this in? Hell the 850 4 valve would be nice in the Pigaso Motar (wishfull thinking).
TX REDNECK (R.I.P.) Posted February 12, 2006 Posted February 12, 2006 Did someone say 4 Valve DOHC?, 103HP WOOF Nope, not here You must be on a different channel
Guest ratchethack Posted February 12, 2006 Posted February 12, 2006 Nope, not here You must be on a different channel Check the tech data sheet on the big motor (at the crank).
TX REDNECK (R.I.P.) Posted February 12, 2006 Posted February 12, 2006 If I need all that hi-tek gizmo crap I'd buy a Jap bike. I don't know, maybe it's just me but, the simplicity of the Guzzi motor is what appeals to me Give me a simple air cooled pushrod motor anyday
Guest golden goose Posted February 12, 2006 Posted February 12, 2006 Aprilia is just sooooo with it! Look, it has chain final drive! The power transmission system of choice for the automotive industry! Right up til 1906..................
Murray Posted February 13, 2006 Posted February 13, 2006 Umm anyone else see a problem with this picture. 103hp @ 8000rpm put of the dual overhead cam motor. Errmm one of the main advantages of dual overhead cam is it lightens the load on the valve train which means you can use lighter springs, pull more rpm more hp. Even Guzzi's four valve motor in Daytona RS form at least reved harder than that. Aprilias dirt bike 450 sohc V twin goes to something stupid like 13 000 rpm with 60hp out of the 450 and 70 out of the 550. Athough admittedly Guzzi is in a simlar postion to HD they can't keep punching out the same motor they have for the last 40years bung it in a frame and call it a sports bike and be taken seriously. The bore stroke is very oversquare athough why are they bothering with an 850 or does it slip in under some of the power to wieght restrictions for various liences or insurance catogries. Chain drive for a bike is signifcantly lighter and mroe efficent in trasfering the power if this motor makes it into a Guzzi maybe we are going to see a serious tilt at a performance Guzzi. Just remeber about a year maybe two ago Gilera showed a concept bike with push button / auto transmission it was a 850 V twin, probally the beastie from this project athough it looks pretty far along for a concept.
luhbo Posted February 14, 2006 Posted February 14, 2006 ..... Chain drive for a bike is signifcantly lighter and mroe efficent in trasfering the power if this motor makes it into a Guzzi maybe we are going to see a serious tilt at a performance Guzzi. ..... 78345[/snapback] If it's that easy you can have it everyday. Aprilia did it already, just changed the color and a bit plastic and, voilà, ready was the new Laverda. At least they thought so... Hubert
