TwinMax Vacuum Line Adapters
Guest SFGUZZI
Ok Folks need some help..
Can anyone tell me the fitting size for the vacuum ports on the v11 , I'm ordering a TwinMax balancer and have a 5mm or 6mm option for the vacuum adapters.
which one..???? 5mm or 6mm
Thanks
SF
Guest SFGUZZI
I have a TwinMax and don't use any adapters...the hoses off the unit fit the ports on the heads just fine as is. :thumbsup:
Randy
78747[/snapback]
Thanks Randy...!!!!!
Fine piece of kit, the Twinmax.
IIRC they come with a selection of adaptors anyway should you need them for any other application. My experience with them is like Randy says though....I have never needed to use them.
I have tried all different sorts of methods and find this by far the best.
Quick, easy and accurate.
Good choice.
Nige. :thumbsup:
