al_roethlisberger Posted April 23, 2003 Posted April 23, 2003 ...funny you ask, because it apparently varies. This sorta ties into the various "airbox/ram-air" and "vapor-lock/fuel-pump" threads, because apparently MG has modified the location of both the voltage regulator, and the fuel pumps at least during the 2001/2002 model year. One can only guess as to "why", perphaps a result for the "parts bin" manufacturing process, or maybe a mid-year correction to address the fuel-pump overheating... who knows. But anyway, on *my* 2002 LeMans, the voltage regulator is smack between the two front horns. However, if you take a look at the photo of Jaap's 2002 LeMans below, you will see what appears to be the fuel-pump in that location(as has been reported on several other pre-2003 V11 LeMans) as opposed to it's location under the frame such as on mine. So, the answer is that on some bikes, it will be mounted above the oil-cooler, between the horns.... or?? I don't know the alternate location al
