richard100t Posted April 1, 2006 Share Posted April 1, 2006 I'm putting the new front tire on my bike & re assembling the front wheel to the bike. I'm having a very hard time getting the bolt to thread into the fork. I tried doing it with the wheel out to see if the bolt would thread just to make sure its not too stripped & it starts & threads just fine. I'm putting the spacer in the right place, I have the pinch bolts loose, the calipers are out of the way. Is there a trick to doing this that I forgot from the last time I did it? Link to comment Share on other sites More sharing options...
dlaing Posted April 1, 2006 Share Posted April 1, 2006 My bike does not thread in, but I imagine from the thread side you can check the alignment with a flash light or a chopstick. Otherwise, you could be getting hung up on the other side. Sometimes I get a lever under the tire to help me align it. Just lifting the tire can be hard to get the alignment spot on. Link to comment Share on other sites More sharing options...
antonio carroccio Posted April 2, 2006 Share Posted April 2, 2006 Technical thread...... Link to comment Share on other sites More sharing options...
g.forrest Posted April 2, 2006 Share Posted April 2, 2006 get back to wheel..away from puta.. ''and work it out'' Link to comment Share on other sites More sharing options...
richard100t Posted April 2, 2006 Author Share Posted April 2, 2006 Ok the Guzzi Gods have smiled on me this morning. I got the new Pirelli Strada on the front this morning. I just took it around the block & my initial impression is its a little taller than the Supercorsa. I'm heading out for a longer ride to scrub the new tire good so that its safe. I'll give another report on it later when I have more info. Seems like a good deal for $25 so far though. Link to comment Share on other sites More sharing options...
richard100t Posted April 2, 2006 Author Share Posted April 2, 2006 I'm back from a little more riding time on the new Pirelli Strada free front tire. The bike rides just fine as far as I can tell. It doesnt turn quite as fast as the supercorsa track tire I had on before but it isnt too far off from it either. On another subject I changed the rear drive fluid & trans fluids. I used RedLine Heavy Shockproof gear oil. I must report that neither I nor my bike has been shocked yet It does seem to make it a little smoother, but its nothing I can put my finger on & say wow. I think I'll be putting the rear Strada tire on next weekend & I'll log in another update then. Link to comment Share on other sites More sharing options...
