Greg Field Posted April 3, 2006 Share Posted April 3, 2006 I put a Power Commander on the Billy Bob yesterday, and now it seems to run even better. Billy has an X crossover and Mistral silencers, so I used a map Micha gave me for a bike with a cut airbox and Guzzi Ti mufflers. I'd like to play a bit with the map. Is there a patch or somethng that will allow me to do so on my computer, which is a Mac? To help match the map, I also cut a 4x4 hole into just the top flat surface of the airbox. (I'm still using a paper filter 'cause I really distrust K&Ns.) Seemed to unplug it a bit, and really there's no increase in noise that I can detect. That is good. They're too loud with the whole top cut away or with the airbox eliminators. I think I'm gonna stop cutting now. If the stock opening plus the 4x4 opening I added doesn't flow enough air to supply everything the engine can suck in, I'll be very, very surprised. And I really hate ntake noise. Finally I put on a new warranty-takeoff Coppa Italia tank. What a nasty job, draining gas, and swapping fuel pumps and fuel fillers. I fear I did my full yearly quota of environmental damage performing that job. Nevertheless, it runs and looks like a brandnew Guzzi, and I now have $3,350 in it, so I'm very happy with that. Now, I just need to put on some miles to see if it's really a "keeper." Link to comment Share on other sites More sharing options...
guzzijack Posted April 3, 2006 Share Posted April 3, 2006 I put a Power Commander on the Billy Bob yesterday, and now it seems to run even better. Billy has an X crossover and Mistral silencers, so I used a map Micha gave me for a bike with a cut airbox and Guzzi Ti mufflers. I'd like to play a bit with the map. Is there a patch or somethng that will allow me to do so on my computer, which is a Mac? Greg, I think you'll have to spring for a PC emulator such as Virtual PC or similar to run the PC software. If your PCIII is not a USB version you'll also have to get a USB to (I think) serial port adaptor to run inside the emulator. It's what I've had to do but then again I have the PCIII for the '97-'99 V11 EV with the P8 brain box that Todd was selling which doesn't have USB so things have moved on a bit since then. Graham Link to comment Share on other sites More sharing options...
Greg Field Posted April 3, 2006 Author Share Posted April 3, 2006 Thanks. We have PCs at work, so I'll just do my playing after hours there. GF Link to comment Share on other sites More sharing options...
guzzijack Posted April 3, 2006 Share Posted April 3, 2006 Thanks. We have PCs at work, so I'll just do my playing after hours there. GF 84798[/snapback] Are you going to ride the BB into the office and hook it up Bettter turn the extract fans on first Graham Link to comment Share on other sites More sharing options...
