orangeokie Posted April 17, 2006 Share Posted April 17, 2006 Does anyone have a photo of the V11 unit, or could you comfirm if this unit would plug and play with a an '03 V11 LeMans? Genuine Aprilia European headlight switch for '98-'00.5 Mille, Mille-R, and '00-'03 Falco. This switch can also be used on '01-'03 Mille, Mille-R, and '02-'05 Tuono. This headlight switch puts the turnsignal switch in the correct location (above the horn switch), AND permits you to turn off the headlight. This part is valuable because it permits you to shut off the headlamp, useful on trackdays. With this switch you do not have to pull the fuse that controls the headlights. Aprilia part no. 8124261 Link to comment Share on other sites More sharing options...
DeBenGuzzi Posted April 17, 2006 Share Posted April 17, 2006 if this is true it would be nice just to have it. turn the lights off for starting and what not. Link to comment Share on other sites More sharing options...
Mike Stewart Posted April 17, 2006 Share Posted April 17, 2006 I am pretty sure the connectors are different. I have the US version from my Aprilia days that I am going to use on my Jackal project and I will have to change the terminals and connector. It also has the switch for the lap timer which won't be used on the Guzzi. Humm, perhaps you could install the Aprilia speedo cluster too Mike Link to comment Share on other sites More sharing options...
Guest ratchethack Posted April 17, 2006 Share Posted April 17, 2006 With this switch you do not have to pull the fuse that controls the headlights. Err,....how long does it take you to pull the fuse? Just checkin'... EDIT: This headlight switch puts the turnsignal switch in the correct location (above the horn switch) The V-11 turnsignal switch IS above the horn switch. The Aprilia one in y'er photo has it the other way 'round. Link to comment Share on other sites More sharing options...
O2 V11 Posted April 17, 2006 Share Posted April 17, 2006 orangeokie, here is a pic of mine. Rob Link to comment Share on other sites More sharing options...
orangeokie Posted April 17, 2006 Author Share Posted April 17, 2006 orangeokie, here is a pic of mine.Rob 86293[/snapback] Thanks, but what I was wondering is if the "plug" is the same. Link to comment Share on other sites More sharing options...
Mike Stewart Posted April 17, 2006 Share Posted April 17, 2006 Well, I just checked the wiring diagram and the guzzi uses a 10 terminal connector and the Aprilia uses a 9 terminal connector, so it will not be a plug and play deal. The terminals are different as well, the Guzzi is a spade design and the Aprilia is more of a bullet design. Mike Link to comment Share on other sites More sharing options...
dlaing Posted April 17, 2006 Share Posted April 17, 2006 Err,....how long does it take you to pull the fuse? Just checkin'... 86291[/snapback] If you pull the fuse to the headlights and stop light on the earlier V11s you also lose the starter. However you can pull the headlight relay...if you can figure out which one that is. Not sure what you would do about taillight/stoplight....pull the bulb???Tape it up???? I am sure the trackies on the list no all about it. Link to comment Share on other sites More sharing options...
Paul Minnaert Posted April 17, 2006 Share Posted April 17, 2006 here is the v11 2001 version of the second one from top. See: different connector? But I think the 2003 and newer bikes with switches like the first one might have different connectors. Why not order the european guzzi switches? v11 sport 01738030 europa 01738035 usa the 2002 has this: I think these are the new style switches. 8 01 73 80 90 1 Dispositivo luci Sx. L.H. lights device Europa 8 01 73 80 95 1 Dispositivo luci Sx. (USA-J-NZ) L.H. lights device (USA-J-NZ) Link to comment Share on other sites More sharing options...
orangeokie Posted April 17, 2006 Author Share Posted April 17, 2006 Thanks for everyone's help. Link to comment Share on other sites More sharing options...
Greg Field Posted April 17, 2006 Share Posted April 17, 2006 I have the Euro switch on Billy Bob. I think it's the earlier one, for pre-02 Sports. Also, it's REALLY easy to wire in a ground-interrupt switch to kill the headlights. You can even buy generic pre-wired versions from Parts Unlimited and the other big distributors. You could even drill a hole in the headlight bucket and install a toggle switch to interrupt the ground. Link to comment Share on other sites More sharing options...
polebridge Posted April 19, 2006 Share Posted April 19, 2006 Hey Orangeokie, How are you enjoying that Guzzi? I know you had an unfortunate (and painful) separation from your Falco. Sorry. The bight side is you now have a very nice MG. I still have, and ride, my Falco but I must say that I am enjoying my new Moto Guzzi more these days. It is such a nice ride. A very different experience compared to the Falco. Those Falcos have got some balls, but there is just something about the MG...it's great isn't it? Link to comment Share on other sites More sharing options...
Mike Stewart Posted April 19, 2006 Share Posted April 19, 2006 I had a Falco also, really fun bike but it just sat in the garage. It had many upgrades (OZ wheels, carbon front fender, Ohlins shock, factory carbon pipes, factory chip and much, much more). I just like the soul of the Guzzi better And, I never had a problem with the Guzzi wiping out my dash settings if the battery went low from sitting two weeks Got to love the Guzzi Mike Hey Orangeokie, How are you enjoying that Guzzi? I know you had an unfortunate (and painful) separation from your Falco. Sorry. The bight side is you now have a very nice MG. I still have, and ride, my Falco but I must say that I am enjoying my new Moto Guzzi more these days. It is such a nice ride. A very different experience compared to the Falco. Those Falcos have got some balls, but there is just something about the MG...it's great isn't it? 86569[/snapback] Link to comment Share on other sites More sharing options...
orangeokie Posted April 20, 2006 Author Share Posted April 20, 2006 Hey Orangeokie, How are you enjoying that Guzzi? I know you had an unfortunate (and painful) separation from your Falco. Sorry. The bight side is you now have a very nice MG. I still have, and ride, my Falco but I must say that I am enjoying my new Moto Guzzi more these days. It is such a nice ride. A very different experience compared to the Falco. Those Falcos have got some balls, but there is just something about the MG...it's great isn't it? 86569[/snapback] I'm lovin' it! Just ordered a set of Ti slip-ons from MPH. Should be here any day. Can't wait to install them and listen to the soul of that V11! I get nothing but compliments from everyone who sees the Rosso Corsa in the flesh. If it wasn't for this forum, I doubt I would have bought one. Link to comment Share on other sites More sharing options...
