:bier::bier::bier::bier::2c::bier::bier:
I had my V11 Sport Transmission apart. The transmission was leaking from the seams from the last 4 times the hack mechanic had it apart.
There were a few things wrong that I found as well. But I'll skip that and cut to the point.
There are four locknuts & lockwashers in the V11 Sport Transmission. They hold the shafts against the bearings and the clutch spline on the main shaft. I replaced them. Sourcing from Guzzi would take too long. After talking with Mark Etheridge he gave me a size for the Eldo 5 speed. That is where my search began.
I finally got a set from Eastern Bearing supply. BUT that took a week. I decided to find a quicker source. Here is what I found.
All Loop, Tonti and Spline frame transmissions use locknuts and lockwashers. I found the manufacturer of locknuts and lock washers in Central Falls,Rhode Island. They will ship same day and the cost is about $2 each
The company website is
http://www.whittet-higgins.com/
Locknuts (metric) are
http://www.whittet-higgins.com/part.php?series_id=43
V11 Sport - There are (2) KM 3 locknuts in the transmission
V11 Sport - There is (1) KM 4 locknut in the transmission
V11 Sport - The clutch spline locknut is size KM 5
Lock washers (metric) are
http://www.whittet-higgins.com/part.php?series_id=50
Match the lockwasher to the locknut size.
Whittet-Higgins also sells TOOLS Spanners, Sockets AND Thread Repair dies!!!!!!!
http://www.whittet-higgins.com/part.php?series_id=76
http://www.whittet-higgins.com/part.php?series_id=79
Not sure of the Loop or Tonti size for the clutch spline. I believe it is a KM 3.
