Baldini Posted May 1, 2003 Posted May 1, 2003 Can someone tell me - how do I remove the pin holding the rear of the torque arm to the top of the drivebox? After undoing the locknut do I drift the pin out (it does not slide easily tho it does rotate) or do I have to remove the mounting bracket from the top of the drivebox bringing the pin with it?
Paul Minnaert Posted May 1, 2003 Posted May 1, 2003 Basic, the pin should come out after unlocking the nut, but maybe a bit of oxidation is in between. Or the 2 alu parts where the pin is going through are not inline, then loosen the 2 screws a bit that hold them to the reardrive.
