Guest Russell Posted April 24, 2006 Share Posted April 24, 2006 Just picked up my new Ballabio. (2004 Model) Whine in 5th gear under load. Not even 100klms yet so maybe too early to be concerned. Question is whether this is normal. A few missed shifts also, mainly into 5th or 6th. I expect these to dissapear once box is worn in a bit. Appreciate any input into this. Link to comment Share on other sites More sharing options...
pete roper Posted April 25, 2006 Share Posted April 25, 2006 Run it in for a bit and see if it improves. if it persists in missing shifts it would probably be worth having a fiddle with the pawl adjuster. Where in Oz are you? pete Link to comment Share on other sites More sharing options...
orangeokie Posted April 25, 2006 Share Posted April 25, 2006 Just picked up my new Ballabio. (2004 Model)Whine in 5th gear under load. Not even 100klms yet so maybe too early to be concerned. Question is whether this is normal. A few missed shifts also, mainly into 5th or 6th. I expect these to dissapear once box is worn in a bit. Appreciate any input into this. 87188[/snapback] Try just snicking the gears with very light clutch action. These bikes really don't require much of a pull on the lever to snick it up and down. Link to comment Share on other sites More sharing options...
Guest Russell Posted April 25, 2006 Share Posted April 25, 2006 Run it in for a bit and see if it improves. if it persists in missing shifts it would probably be worth having a fiddle with the pawl adjuster. Where in Oz are you? pete 87196[/snapback] Hi Pete Thanks for the reply. Tamborine Mountain just in from the Gold Coast. Also my wife has a Breva 750 and loves it. The gears are as slick as, with no whine etc. I will do as you suggest and put up a few miles and see if everything beds in. This is usually the case with minor problems. Only reason for the query was the demo bike I rode (700 klms) did not appear to have the whine in any of the gears. Regards Russ Link to comment Share on other sites More sharing options...
