mdude Posted April 27, 2006 Share Posted April 27, 2006 Noticed that my headers are becoming increasingly more blue after installing the Titanium kit. What is the reason for this? Sign of trouble? I have not yet got around to adjusting valves and synching TPS's, will do in two weeks time. EDIT: yeah Martin, I remember now that it is sympthom of lean running, any immediate fixes which dont include electronics? Link to comment Share on other sites More sharing options...
Martin Barrett Posted April 27, 2006 Share Posted April 27, 2006 Indicates running too lean, burning too hot. Could lead to trouble. I'm sure some one more knowledgeable will advise shortly. Link to comment Share on other sites More sharing options...
dlaing Posted April 27, 2006 Share Posted April 27, 2006 You probably should not be too concerned. It may be worth pulling the spark plugs to make sure they are not grey or melting. Luhbo did a great comparison of the Ti Map with the standard map. If you PM me your email address I can send you the Excel file. The Ti map mostly enrichens but it leans out in some areas. But the Ti map also advances the timing in a few places that could also increase the heat. Checking valves and TPS should not be delayed if the spark plugs are at all showing hot running conditions. Link to comment Share on other sites More sharing options...
dlaing Posted April 27, 2006 Share Posted April 27, 2006 I have not yet got around to adjusting valves and synching TPS's, will do in two weeks time. 87460[/snapback] That should be, I have not yet got around to adjusting valves and TPS and synching TB's, will do in two weeks time. Link to comment Share on other sites More sharing options...
mdude Posted April 28, 2006 Author Share Posted April 28, 2006 That should be, I have not yet got around to adjusting valves and TPS and synching TB's, will do in two weeks time. 87477[/snapback] I most humbly apologize Link to comment Share on other sites More sharing options...
dlaing Posted April 28, 2006 Share Posted April 28, 2006 I most humbly apologize 87538[/snapback] Apologies are for sissies! Next time just give a good Did you check your spark plugs? Link to comment Share on other sites More sharing options...
