dmoon64 Posted April 29, 2006 Posted April 29, 2006 Should they be considered consumables. After replacing the relay bike started and ran fine for about 200-250 miles. Yesterday started with the same symptoms. Needed to turn stuff on/off to get it to start, then dies in traffic a couple of times. 2003 LeMans. Is is a bad relay or something causing relay to act wonky?
pete roper Posted April 29, 2006 Posted April 29, 2006 I wouldn't think so. Have you considered seeing if there is a slightly higher capacity relay available? Alternatively it could simply be a bad connection, probably an earth, somewhere else in the system. By 2003 I thought that they'd stopped using the failure prone Seimens relays. One of the other blokes with more experience of these than me should be able to tell you. Pete
Ouiji Veck Posted April 30, 2006 Posted April 30, 2006 Did you go with a GEI or Bosch relay instead of the Seimens? And I've seen here that sometimes it's the socket. You can get a handful (5) of GEIs from http://www.dpguzzi.com/relay.htm for about $15.00
Guest ratchethack Posted April 30, 2006 Posted April 30, 2006 Should they be considered consumables. After replacing the relay bike started and ran fine for about 200-250 miles. Yesterday started with the same symptoms. Needed to turn stuff on/off to get it to start, then dies in traffic a couple of times. 2003 LeMans. Is is a bad relay or something causing relay to act wonky? dmoon, could be a coupla things. Check the discussion here: http://www.v11lemans.com/forums/index.php?...60799entry60799
Van Posted April 30, 2006 Posted April 30, 2006 Did you go with a GEI or Bosch relay instead of the Seimens?And I've seen here that sometimes it's the socket. You can get a handful (5) of GEIs from http://www.dpguzzi.com/relay.htm for about $15.00 87742[/snapback] Get the relays from Dan, the service is worth the price of admission alone !! Cheers Van
waspp Posted April 30, 2006 Posted April 30, 2006 My 03 has tyco relays and I haven't yet experienced any issues. From your description I would agree with the all guzzi wise pete roper, sounds like a loose connection somewhere. waspp
Guest Nogbad Posted April 30, 2006 Posted April 30, 2006 I am STILL waiting for a Siemens relay to go down..........
DeBenGuzzi Posted April 30, 2006 Posted April 30, 2006 I am STILL waiting for a Siemens relay to go down.......... 87787[/snapback] you're a rare breed there noggy, rare indeed. Mine had been replaced with bosch b4 I bought the bike slighty used and I didn't know it. I was having relay problems, bike never quit on me just lights, dials and horn problems My bike is basically on its third set of relays if these tank at all I'm going higher capacity all around. like its been said sounds like a loose ground or lets not even think about a messed up ECU. , nah I'm sure youre wires are loose give'em a good once over.
dmoon64 Posted April 30, 2006 Author Posted April 30, 2006 This was a Dan at DPGuzzi relay. Sorry Wasn't a DPGuzzi relay. Siemens and Tyco brand. The starter relay is the third one in from the front. Then I have two smaller relays.
Guest Nogbad Posted April 30, 2006 Posted April 30, 2006 you're a rare breed there noggy, rare indeed. Mine had been replaced with bosch b4 I bought the bike slighty used and I didn't know it. I was having relay problems, bike never quit on me just lights, dials and horn problems My bike is basically on its third set of relays if these tank at all I'm going higher capacity all around. 87790[/snapback] I think this relay problem affects more US bikes with AHO. The UK bikes with a FREEDOM headlight switch are better!
