kevdog3019 Posted May 26, 2006 Share Posted May 26, 2006 I'm going to do a valve adjustment on the Lemans and was wondering if I need to take off the fairing to get the valve covers off? It sure looks tight to get at the two rear bolts. Is this an easy job (taking off fairing)? Only looks to be held on by 4-6 screws. Thanks! Link to comment Share on other sites More sharing options...
Guzzirider Posted May 26, 2006 Share Posted May 26, 2006 I'm going to do a valve adjustment on the Lemans and was wondering if I need to take off the fairing to get the valve covers off? It sure looks tight to get at the two rear bolts. Is this an easy job (taking off fairing)? Only looks to be held on by 4-6 screws.Thanks! 90417[/snapback] Taking off the fairing is an easy job- mirrors, four bolts and disconnect indicators if my memory serves me correctly, but you wont need to take it off to remove valve covers. Guy Link to comment Share on other sites More sharing options...
rocketman Posted May 26, 2006 Share Posted May 26, 2006 I'm going to do a valve adjustment on the Lemans and was wondering if I need to take off the fairing to get the valve covers off? It sure looks tight to get at the two rear bolts. Is this an easy job (taking off fairing)? Only looks to be held on by 4-6 screws.Thanks! 90417[/snapback] I remove the fairing to adjust the valves. Rocketman Link to comment Share on other sites More sharing options...
Garsdad Posted May 27, 2006 Share Posted May 27, 2006 I loosened the two bolts that attatch it to the frame, removed the one support at the head, and had no trouble getting to everything. Ryan Link to comment Share on other sites More sharing options...
