Guest kjh Posted June 25, 2006 Share Posted June 25, 2006 Hi all, The rear shock on my 2003 V11 is seeping oil through the seal. Can these shocks be repaired? is there anyone in the UK that can fix and rebuild them? What are the alternatives to the oem shock, I know about the ohlins shock, but is there any other alternatives that I can use. Cheers. Link to comment Share on other sites More sharing options...
Guzzirider Posted June 25, 2006 Share Posted June 25, 2006 I believe Maxton make a decent shock which they will build to your specification. Maxton Link to comment Share on other sites More sharing options...
gthyni Posted June 25, 2006 Share Posted June 25, 2006 I have a spare Sachs unit laying around somewhere mail me if you want to buy it for a decent price. Link to comment Share on other sites More sharing options...
big J Posted June 25, 2006 Share Posted June 25, 2006 I've got one of the Maxton shocks.Very pleased with it,though it can be difficult to determine which is best on the billiard table smooth surfaces down here. Compared to the stock Sachs,it's as different as something which is very very different indeed.But in a good way. Put it this way,after a spin,I lick it clean.Give you any idea how much better it is? Link to comment Share on other sites More sharing options...
Guest Nogbad Posted June 25, 2006 Share Posted June 25, 2006 If you are offered a replacement Sachs, it should be free. I wish mine would burst so I have an excuse to change it. Link to comment Share on other sites More sharing options...
Dan M Posted June 26, 2006 Share Posted June 26, 2006 Hi all, The rear shock on my 2003 V11 is seeping oil through the seal. Can these shocks be repaired? is there anyone in the UK that can fix and rebuild them? What are the alternatives to the oem shock, I know about the ohlins shock, but is there any other alternatives that I can use. Cheers. 93270[/snapback] I changed to a Wilbers unit. Made to spec. Coudn't be happier with it. Link to comment Share on other sites More sharing options...
gthyni Posted June 26, 2006 Share Posted June 26, 2006 I use a Paioli unit taken of a Laverda Zane, its fully adjustable, even a bit in length (seat height). I works very well on the heavier V11 since a was a bit on the stiff side on the Laverda according to reliable sources. Link to comment Share on other sites More sharing options...
dlaing Posted June 26, 2006 Share Posted June 26, 2006 http://www.v11lemans.com/forums/index.php?showtopic=5488&hl= Link to comment Share on other sites More sharing options...
jihem Posted June 26, 2006 Share Posted June 26, 2006 I use a Paioli unit taken of a Laverda Zane, 93303[/snapback] scusi but...what imodel is a laverda zane ? Link to comment Share on other sites More sharing options...
gthyni Posted June 26, 2006 Share Posted June 26, 2006 scusi but...what imodel is a laverda zane ? 93312[/snapback] http://668tech.laverda-nz.org/ Link to comment Share on other sites More sharing options...
Guest kjh Posted June 26, 2006 Share Posted June 26, 2006 http://668tech.laverda-nz.org/ 93316[/snapback] Hi folks, Many thanks for all the info, gives me plenty of food for thought, nice to know theres plenty of options. The roads around here are plenty bumpy, so need a shock that can take the abuse. Cheers to all. Link to comment Share on other sites More sharing options...
jihem Posted June 26, 2006 Share Posted June 26, 2006 thanx for the Lav' pic ! I just got confused if there was ever a model called Zane Link to comment Share on other sites More sharing options...
big J Posted June 26, 2006 Share Posted June 26, 2006 Hi folks, Many thanks for all the info, gives me plenty of food for thought, nice to know theres plenty of options. The roads around here are plenty bumpy, so need a shock that can take the abuse. Cheers to all. 93317[/snapback] Bumpy????? Pah! You boys up there dont know when you've got it good.Come down to Meath.Last week I went into a pothole and didnt come out the other side for 3 days. Link to comment Share on other sites More sharing options...
