What can I do to keep moisture from getting in to my head light. Not driving in the rain is a poor solution. I went for a ride in light rain on Sunday and the lense was covered with droplets on the inside.
The lamp on my 2000 Sport is different but perhaps you should take the thing apart and be sure the seals are all in place. Maybe one got crimped in assembly.
also the '02 bucket is a plastic affair. Check it for splits or cracks. I seem to recall access to the lamp requires fairing removal. One of the Lemans boys will surely confirm or deny this for you . . .
Yes the fairing needs to come off to get to the Headlight (you would need to do this to change the bulb !! :stupid: ) I've got moisture in mine also but haven't had chance to look for a solution. :doh:
While your at it check the mountings out as mine had quite a lot of play in the various bushes (the headlight seemed loose ), wrapping the bushes and bolts with pvc tape took the clearance out and cured it easily. :luigi:
