Sam38a1 Posted June 30, 2006 Share Posted June 30, 2006 Helllo, My turn signal lamp went out on my 2004 V11 Ballabio. I remove it and went to 2 auto parts stores and to my Moto Guzzi dealer and nobody has a turn signal lamp that would fit. The pins on the lamp are at 130 degrees not like most lamps that are at 180. So I found a lamp that was 10 amps(anything lower then 10 amps the turn signal flasher will not work) and ground down one of the pins and it works. But it's white and a little to large. I hope it will not melt my trun signal lens. The Dealer said they will order them from the Factory. But that could take a long time. Sam Link to comment Share on other sites More sharing options...
MINNESOTALEMANS Posted June 30, 2006 Share Posted June 30, 2006 Helllo, My turn signal lamp went out on my 2004 V11 Ballabio. I remove it and went to 2 auto parts stores and to my Moto Guzzi dealer and nobody has a turn signal lamp that would fit. The pins on the lamp are at 130 degrees not like most lamps that are at 180. So I found a lamp that was 10 amps(anything lower then 10 amps the turn signal flasher will not work) and ground down one of the pins and it works. But it's white and a little to large. I hope it will not melt my trun signal lens. The Dealer said they will order them for the Factory. But that could take a long time. Sam 93680[/snapback] sam try abuell dealer or check how to section on page 4 buell turn siganls i think the ones of a s2 will work Link to comment Share on other sites More sharing options...
OldButNotDead Posted June 30, 2006 Share Posted June 30, 2006 Helllo, My turn signal lamp went out on my 2004 V11 Ballabio. I remove it and went to 2 auto parts stores...[clip] Sam 93680[/snapback] Auto parts store?...for the Guzzi?..... Sorry, but you're not in Kansas anymore Toto. The Buell solution works well. Reading this board is your only Salvation now. Learn the mysteries of the "Search" function and all shall be revealed. Praise be to Jaap. Link to comment Share on other sites More sharing options...
richard100t Posted June 30, 2006 Share Posted June 30, 2006 For under $20 you can buy a set of aftermarket turn signals at almost any bike shop. For about $40 you can upgrade to a set of led signals. Guzzi parts are usually overpriced & hard to get. Fwiw I'd look at the aftermarket stuff Link to comment Share on other sites More sharing options...
DeBenGuzzi Posted June 30, 2006 Share Posted June 30, 2006 buell turn signals (identical btw and made in italy too) $6 don't have to work herder here mang. but I like your go getting get'erdone attitude Link to comment Share on other sites More sharing options...
orangeokie Posted June 30, 2006 Share Posted June 30, 2006 I replaced my lenses with the smoke Buell and these amber bulbs. clicky di picky Link to comment Share on other sites More sharing options...
DeBenGuzzi Posted June 30, 2006 Share Posted June 30, 2006 I replaced my lenses with the smoke Buell and these amber bulbs. clicky di picky 93739[/snapback] what size are these exactly? I don't see numbers I am looking for visual ambers!!! ya know the silver ones that blink amber Link to comment Share on other sites More sharing options...
orangeokie Posted July 1, 2006 Share Posted July 1, 2006 what size are these exactly? I don't see numbers I am looking for visual ambers!!! ya know the silver ones that blink amber 93746[/snapback] Send "Ed" an email at AF1. He can and will answer all your questions. Link to comment Share on other sites More sharing options...
