Now it is broken clutch
kecup
Does it have the p.i. (hydraulic lifter) engine? If not, no worries about having the 1-plate clutch.
95025[/snapback]
I don't know about the hydraulic lifter bit though, Greg.
What's the easiest way to find out?
It is an injection model.
Tonti frame 5 speed tranny.
Clutch is cable operated.
Nige. :unsure:
Thanks for advice - I have adjusted the cable for some freeplay (had almost none) and it did not help- I will do more and also check the clutch lever and report back.
Pavel
Ranting and railing against the fates will serve no purpose so make your decision based o whether you like the bike, (In which case you carry out the repairs.) or you decide it isn't worth it and turn it over at a loss or try to wreck it out and recoup your loss. Either way you can chalk it up to a learning experience.
94967[/snapback]
The warranty left aside my point was how this can happen - a bike that has 5K miles can get its clutch broken, but not as a reason of a bad design everyone knows about.
The guzzi certainly has its attraction to me - just painfully learning the rules of the trade.
Richard, the Cali clutch problems are completely different to the Scura ones.
Yes, I think there shoukld be a recall on the Scura clutches, but i don't think it will happen. The difference with teh Cali clutches is that there HAS been a recall. The CAli clutches, unlike the Scura clutches, don't grenade the flywheel, the problem is a fiction material one, the bronze stuff they used wears far too quickly, whether this was poor choice of material or simply a duff batchfrom their supplier who knows but wear out they do.
94937[/snapback]
Well if, as I suspect it is now, it is a single plater in the Cali I have, at least it won't go super nova on me! ^_^
Thanks for that info, Pete! :thumbsup:
Nige. B)
Nige.  :unsure:
95026[/snapback]
Nige, whip a rocker cover off. If it's a Hydro model there won't be any tappet adjuster lock-nuts on the rockers.
If it is a hydro model it should say 'Idrauliche' or 'PI on it somewhere though.
Pete
Pete
95039[/snapback]
Thanks a lot, Pete!
That is the information I needed! :thumbsup:
I'm off to bed shortly.
I'll take a skeet tomorrow and report back, just to add a small contribution to the forum database. ;)
Nige. B)
Never in the field of home mechanicing, have I ever been so relieved to see an adjustable tappet! :bier:
:bier::bier:
Yahay! :thumbsup:
BUT!
Jeez! I have never seen emulsification like it!!! :o
The rocker arms and tappets had a 1mm thick coating on them!! :vomit:
Mind you, the bike had less than 1,700 miles on it when I bought it, and had been stood for some time.
I only take rides over 70 miles or so, so I suppose this is down to the short runs the previous owner must have given it.
Oil & filter change moves right up the priority list! :luigi:
Thanks for the input, folks!
Nige. :thing:B)
